Go to Post Just because we don't cheer, doesn't mean we don't have fun. ;) - JVN [more]
Unread 02-07-2016, 22:38
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
pic: Inverted Gearbox Concept
Unread 02-07-2016, 22:57
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: pic: Inverted Gearbox Concept
Maybe this isn't an issue, but the exposed 1st stage looks like an accident waiting to happen. If it were used one would want to be careful with the chassis design to make sure nothing (wires, etc.) would be in danger of getting nailed.
Unread 02-07-2016, 23:11
AKA: Daniel Koh
Team Role: CAD
With every design like this, the first stage will be exposed. Of course, people should be careful about this, but perhaps a case can be made to go over the first stage. I can kind of imagine that happening with a 3d printer.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 03-07-2016, 10:31
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Why spend the time printing something heavy and fragile (and doesn't let you see inside) when you could run a thin sheet plastic shield? I know some teams were using lexan for this but that seems overkill... scrap plastic like out of a 2L bottle seems all that would be necessary here.
Unread 04-07-2016, 00:23
ratdude747's Avatar
AKA: Larry Bolan
Exactly. I didn't say it wasn't fixable, and pop bottle fixes are 100% valid here. My concern was more of a "if you use this type of design, take care...", not a "this design is doomed and all teams should avoid it".
Part of it is my new job as an engineer in an automotive body component plant where I'm always having to take such precautions when designing/modifying machinery. Unguarded pinch points cause me to raise an eyebrow... which maybe isn't bad?
Unread 04-07-2016, 00:33
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Out of curiosity, what size gears are you using on your first reduction?
Unread 04-07-2016, 01:00
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We had a similar setup in 2015. The gears are too far above the belly pan to really grab anything.
I wouldn't be worried unless your 1678.
2016: FRC 865 Mentor
Unread 04-07-2016, 01:27
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The outboard placement of the CIMs looks good, but the high CoG is disconcerting. Rotating the whole assembly about 60 degrees about the output shaft (pick your direction) and moving the then-higher CIM closer to the then-lower CIM would result in a much lower center of gravity and a shorter foundation for the manipulators, without much affecting the shift and other capabilities.
Unread 04-07-2016, 09:34
ratdude747's Avatar
AKA: Larry Bolan
I've seen worse. Not that I think the sort of teams that are usually guilty of rat nesting would be making their own gearboxes; but I've seen good teams get bit by wire snares (like 1108 at Crossroads Regional Finals in 2013, that was a smoky example). Yeah, common sense, but even good teams make mistakes (Einstein 2012?).
