Go to Post Note to self: Go to IRI sometime. - [more]
Unread 03-07-2016, 00:29
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: FRC team 179 IRI 2-Ball AUTO
Originally Posted by asid61 View Post
That's cutting it close on the timing, but if it works...
Great job from 179 again! Any plans to refine it more before IRI?
Before, during, after, The refining never stops.
Awesome robot as always. Have to ask, has your turret always had the ability to shoot backwards like that, or did you remount it so that the direction the turret is facing now is forward and the intake is on the rear? Great job with the two ball auto, and see you in Indy!
Edit: Also, does this mean you guys can dunk now?
It's always been able to do it, but we limit ourself in software to ~180 deg. due to cable management and have to re-tension the bundle between changing sides. We rotated it before Championship for the cycle efficiency and the 2 ball possibilities. The dunk is still theoretical at the moment but we're looking at it....
