Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
Unread 03-07-2016, 22:03
olidem123 olidem123 is offline
Not a community manager
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
olidem123 is an unknown quantity at this point
Battery not showed?
The driver station is supposed to show the battery voltage (at least, it was last year when we where using labview) however, during the whole year, I wasn't able to see the voltage of my battery on the driver station. Any solutions/explanation?
Unread 04-07-2016, 01:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Battery not showed?
We had no issues this year (with java).
I recall a similar issue a few years ago with the cRIO due to a missing jumper, but the roboRIO documentation simply states (top of page 7):
Originally Posted by NI roboRIO User Manual
The input voltage monitoring circuit monitors the voltage on the input voltage pin. [apparently referring to the difference between black and red wires on the COMBICON power connector]
Unread 05-07-2016, 10:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The Crio depended on the analog card to know the battery voltage. The Roborio pulls it internally. To my knowledge it is not possible to disconnect. The DS function is independent of program language. I recall that it transmits battery voltage without a program running. Does Voltage show up on the chart? Are you running the correct drive station (16.0.2) roboRIO image FRC_2016_V19 and firmware v3.0.0?
Battery voltage also shows up on the FMS. It is hard to imagine that you would get through the season without someone noticing.
Unread 12-07-2016, 22:16
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
The roborio should and driver station should be oh be up to date (or I wouldn't have passed the inspection) and the first one to notice said it before a match in the finals of our regional. He asked if we wanted to change our battery because it was running low and we replied that it was like that since the beginning, even at school.
Envoyé de mon iPhone en utilisant Tapatalk
