Go to Post "There's plenty of room on the top for everyone" ... it's not a top if everyone is there. - Alyssa [more]
Unread 22-01-2002, 09:49
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Gray box limitations
What exactly are the limitations on using the $100 worth of "electrical components" from DigiKey?
Do ALL of the components need to be in the gray box?
Do ALL of the components need to be on the circuit board?
We want to measure shaft speed with a hall-effect sensor. We want to put the sensor near the shaft, but if the components must be in the box (or on the CB) then that presents a problem. One way around this is to use strong magnets on a nearby shaft, sproket or gear that can trigger the sensors in the box. But this approach requires all measured shafts to be in close proximity to the gray box.
Has anyone tested this ruling?
On another note, I consider CB fabrication and any other parts from DigiKey that are explicitly listed in the Additional Parts List as falling outside the $100 limit. Only non-listed components from DigiKey should fall under the $100 limit.
Unread 23-01-2002, 07:38
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I agree with you that the $100 is stuff not on the list otherwise.
I think that FIRST has ruled that all the stuff from Digi-Key has to be in the box.
As to in the box is enough or must it be on the curcuit board, I would think that in the box is enough, but I think that this is a good question for FIRST.
Joe J.
box orientation Lance General Forum 1 13-02-2003 10:12
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
project box archiver 2000 2 23-06-2002 23:01
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
