Go to Post Stratagy drives design, not features. - Wetzel [more]
Unread 04-07-2016, 13:47
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Why won't this PID loop stop?
Originally Posted by team-4480 View Post
I did actually write code so that if it was onTarget(), it would be disabled but it never worked because I found out that if you call onTarget too often, it never returns true.
You are possibly encountering a bug that was discovered this year.
Edit: Or possibly not, as a reply in that thread indicates that bug does not occur in the python version of WPILib. I'd suggest looking through the PIDController code and debugging to find why this is happening.
Edit 2: I have never worked with python myself, so perhaps I'm missing something, but it seems to me that the onTarget() function in the python WPILib doesn't actually, erm, do anything (other than throw a value error):
def onTarget(self):
    """Return True if the error is within the percentage of the total input
    range, determined by setTolerance. This assumes that the maximum and
    minimum input were set using :func:`setInput`.
    :returns: True if the error is less than the tolerance
    raise ValueError("No tolerance value set when using PIDController.onTarget()")
"The breakfast of champions!"
