Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 05-07-2016, 12:50
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Good way to bring shooter to exact speed?
Hi,
We recently decided to put an encoder on our shooter so that we can stop setting the shooter to a percentage of the battery power to an actual rpm. The problem we have now is how do we exactly program it to go to a certain rpm?
My best guess would be to use a PID loop and then limit the output to not include negative numbers so that the shooter doesn't suddenly change directions. We have tried just writing a linear equation like speed = distanceFromRPM * .01 +.4 but that usually didn't work well and the time it took to reach the desired RPM had a huge variation.
We just want a method that takes very little time to get up to the RPM and is consistent. Any ideas are appreciated and welcomed!
#Python4Life
