Go to Post Chiefdelphi is a great resource for all of FIRST to use over the years and has grown into a community that has taken a life of it's own. - Koko Ed [more]
Unread 07-06-2016, 10:04 AM
c557paul c557paul is offline
FTC #3140
c557paul is an unknown quantity at this point
Vexpro 3 CIM Ball shifter, WCD
Hello, I am with 3140 Flagship and we have broken three plastic housing of the VEXpro 3 CIM Ball Shifter, WCD. I initially thought that we may have improperly mounted the drive assemblies, but the next 2 were checked and they broke probably from stress. I there a metal (Al)housing that matches the plastic design or do we need to go with the open metal housing that VEX sells?
Unread 07-06-2016, 10:25 AM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Vexpro 3 CIM Ball shifter, WCD
I just have to ask, are you using Loctite by chance?
Unread 07-06-2016, 10:38 AM
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Along with loctite, are you sure you haven't over-tightened any of the hardware during assembly?
Unread 07-06-2016, 11:18 AM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Hardin Valley used the plastic housing Ball Shifter this year, and I don't think they had any issues with it. May want to shoot them a message, I'm sure they'd be happy to help.
Unread 07-06-2016, 11:35 AM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
What kind of stress? How was the stress applied? What part of the housing cracked? Do you have available pictures of the broken pieces and your setup?
There are many, many ways to set them up improperly, causing increased stress on the components. It may be that we can identify the root cause of the issue and suggest other recommendations for resolving it without needing to replace the gearbox housings with a different design.
2016: Lake Superior WFFA
Unread 07-06-2016, 11:45 AM
FTC #3140
Yes, we use loctite and I don't think they over tighten the bolts. The first one we had break was in recycle rush.
Unread 07-06-2016, 11:46 AM
Chris is me's Avatar
AKA: Pinecone
Short answer: No, there are no COTS closed* metal plate replacements for the ballshifter.
The long answer: You probably did something wrong if you broke it. The case is plenty strong. Loctite should not cause a problem because the case is made from glass filled nylon, not polycarbonate. Was the case exposed to impacts or something? How did you attach it to your drive base? Any pictures of your setup would go a long way toward diagnosing your problem.
Unread 07-06-2016, 01:31 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We've used VEX ball shifters for roughly 3 years now and never had any issues with the housing. My first reaction is that they may be mounted improperly or are being exposed to external forces/impacts that they aren't designed for.
As others have said though, pictures would be a big help.
