Go to Post ...I've changed my position. I'm fully supportive of Joe's suggestion... - Chris Hibner [more]
Unread 06-07-2016, 11:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Good way to bring shooter to exact speed?
Because Y is the output to the motor controller, and the integration of Y is always in the direction to drive the speed toward (and then past) the setpoint... which causes a change in the sign of "e".
Ok, that's not how I had read the original thread. Looking back at it I must have misread:
The hallmark of TBH is the unique way that the output is reset at each zero crossing.
as
Originally Posted by Not-Ether
The hallmark of TBH is the unique way that the output is only reset at each zero crossing.
Thanks for the clarification - this will save me a whole bunch of heartache as I experiment with TBH on a motor driven launcher.
