Go to Post Anyway, everyone, PLEASE READ THE MANUAL VERY CAREFULLY and ask around for the answers before going directly to FIRST. :) - AmyPrib [more]
Unread 07-07-2016, 11:04 AM
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: What is wrong with my Vision to Gyro code?!
You indicated that your PID loop would rotate the robot to 125 degrees instead of the target of -56 degrees. Given that the robot then oscillates around 125 degrees, this sounds like a condition where you need to invert (negate) the output value produced by the PID before applying it to your motors.
When we run across this issue, we typically observe the following:
  • Robot rotates away from target because we are applying power in the opposite direction required to reduce the error.
  • As the robot rotates away from the target, the error increases and the power output increases (it typically speeds up as it "runs away" from the target).
  • Because the PID set to continuous mode, 180 degrees is the farthest away from the target that you can get (so once it goes past that, the PID probably inverts the error on you and you bounce back hard in the other direction).
Try negating the power before applying it to your motors to see if that fixes the problem.
It might also be useful to add a command that rotates the robot 90 degrees every time you press a button (to make sure you get the rotation PID figured out before adding the camera code).
