Go to Post Just as you and your team will make hard decisions as you struggle to build a robot, FIRST has had to make hard decisions concerning maximizing safety while making the number of rules as small as possible. - Mike Betts [more]
Unread 07-07-2016, 17:29
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Very small torsion axles
Originally Posted by cbale2000 View Post
Would anyone care to explain what building this type of axle accomplishes? I think I'm missing something here.
I googled it, and it said that these can be used as suspensions for trucks and the like as opposed to the other method of using leaf springs. That being said I have no idea how these work, although they look really cool.
Unread 07-07-2016, 18:54
RoboChair's Avatar
AKA: Devin Castellucci
It's a small non-rotating square axle around which there is flexible rubber in a tube. The axle cannot rotate in relation to it's mounting hardware. The tube WOULD be able to move freely around the axle except that there is rubber preventing continuous rotation and providing a spring effect relative to the axle.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 07-07-2016, 20:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I wonder if it's possible to shove one of these together while soaked in alcohol or something, without needing to freeze anything.
Unread 07-07-2016, 20:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I bet a pour-able molding urethane might accomplish this.
Unread 07-07-2016, 22:30
Forhire Forhire is offline
AKA: Randy Smith
FRC #4060 (S.W.A.G. 4060)
Rookie Year: 2015
Forhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond repute
Originally Posted by s_forbes View Post
This is a really neat process, thanks for posting it!
Are you using Buna-N type of o-ring material, or does it have to be some other exotic material for this process to work?
As for the die, how did you decide on the dimensions for the triangular shape and o-ring diameter to use?
Thanks. Standard buna-n. Stiffness is dependent on the shore hardness of the
rubber. We modeled the parts in solidworks and then estimated space required. We ended up facing the die about 20 thou to get the compression just right. The V was a standard 90 degree cutter.
Originally Posted by Lil' Lavery View Post
What made you opt for torsion axles over other suspension systems?
Lightweight, compact, no stops required.
This page may help explain everything:
http://www.lovejoy-inc.com/products/...uspension.aspx
Common on trailers. They are also used in track systems like on skid steers. I believe this video was part of the inspiration.
https://www.youtube.com/watch?v=dIImhJMbc88
No. We tried a bunch of methods... pulling, pushing, stretching, and etc. Rubber acts like a liquid under compression. Freezing worked. Liquid nitrogen came from the local welding supply.
After reading a few patents it was clear that potting the axle in rubber or urethane wouldn't accomplish the correct motion and tension. We made a very crude prototype from wood and learned exactly how they work. As the square rotates the rubber rods roll tighter and tighter into the corner. The rolling action was key.
Unread 08-07-2016, 13:08
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Thank you for posting this discussion and sharing the pictures of the process!
What durometer did you end up using on the O-ring material? Did you try other durometers to end up with your final choice?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 09-07-2016, 00:35
AKA: Randy Smith
Rookie Year: 2015
We ordered some soft A50 and medium A70. We used the A50 because it was easier to work and appeared about right.
