Originally Posted by cpapplefamily
one we are using an IP camera so not enough ports on curent switch.
We used
this switch this year with no problems whatsoever. It is 5v, so just power it from the VRM.
, two robot weight current bot weight is 119.999lbs.
A raspberry pi is 0.0683433 pounds. I do not see that putting you over the weight limit, and even if it did, shortening all your wires and zip ties would probably put you back under it. The switch does weigh a little more than the pi, but still not enough to really make a huge difference in your overall bot weight. Overall solution shouldn't be more than a pound.
