Go to Post FIRST is our lever and the mentors are the fulcrum. - Daniel Brim [more]
Unread 08-07-2016, 22:31
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
DrewMatic is an unknown quantity at this point
Chain vs. Belts?!?
Hey everyone. I'm from team 240 T.E.M.P.E.S.T.
The past 2 years we have used chain everywhere. There was one thing that happened, we had to fix the chain a lot more than we liked too. I know this could be due to poor alignment, etc. but next year we plan on using belts.
What are your thoughts on Chains? Belts?
Thanks, Drew
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 08-07-2016, 22:36
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Chain vs. Belts?!?
This is a topic that is discussed quite often.
There is a good white paper written by team 234 which evaluates the power transmission methods:
https://www.chiefdelphi.com/media/papers/2216
Facebook
Unread 08-07-2016, 22:37
DrewMatic's Avatar
Djibouti
AKA: Drew T
Thank you! I'll check it out
Unread 08-07-2016, 22:39
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Its worth mentioning that if the issue was alignment whether you are using chains, belts or interlocking plastic monkeys the issue wont be solved.
If you are using #25 chain and there are alignment issues switching to #35 could help but really the best thing to do is fix the alignment.
If your issue has to do with master links I would buy a dark soul chain remover.
iirc belts actually are more sensitive to being out of alignment so switching to belts is only going to make things worse.
Unread 08-07-2016, 22:44
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
After seeing what 5172 did with poly cord this year, im excited to use it more in the future. Belts don't stretch which is nice, but you have to design around belt size more so than you do with chain. Personally I'm sick of chain, but that's because it cost me a ton of time during Ri3D. It's more difficult to align a chain than it is a belt in my experience.
You can't go wrong either way if you do it correctly. I would suggest looking into poly cord belts as an option.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 08-07-2016, 22:55
ollien ollien is online now
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
For the uninformed, what did 5172 do with polycord?
Unread 08-07-2016, 22:58
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
It is important to consider the advantages of both based on specific applications.
Pros of Chain:
  • Sprockets can be more compact (Slimmer than pulleys.)
  • Chain can be broken to allow for easy servicing.
  • Chain, #35 in particular, can support higher load than belts.
  • Sprockets can be found in COTS solutions in more sizes than belts.
Cons of Chain:
  • Chain, particularly #35 chain, can be heavier than belts.
  • Chain can stretch over time (Chain should be fine for at least 2 regionals if properly tensioner or set for an exact c-c distance).
  • Chain comes in links, it can be a PAIN to deal with chain if you don't use a whole number of links.
  • Chain probably shouldn't be run at higher rpms. I've seen a team explode #25 chain by running it at 5K RPM.
Pros of Belts:
  • Belts come in many sizes. (You may need to buy from sources other than VEX or AndyMark, however.
  • Belts can be much lighter than chain if used in applications within their load range. (Provided you use larger pulleys, you should be able to push their load rating in FRC applications.)
  • Belts are much quieter than chain.
  • Belts do not stretch as much as chains when properly loaded.
  • A broken belt will not shatter (from what I've seen at least!). Flying belt material is safer than flying steel or aluminum.
Cons of Belts:
  • Belts require pulleys than can be much wider than sprockets.
  • Belts are more likely to stretch or break if misaligned or if their C-C distance is inaccurate. (Belts in Drivetrains and many other FRC applications are already being pushed beyond what they're rated for; you will see catastrophic results much easier than chain that isn't being pushed well beyond what it is loaded for.)
  • Belts require a higher accuracy to properly use in comparison to chains. (I've been told ~.003in is optimal).
This document is really helpful for finding information on belts: https://www.gates.com/~/media/files/...ion-manual.pdf
If you want additional information, post here or look for Travis or Austin Schuh. I learned most of this information by reading posts from those two and they are very experienced with using both belts and chains on their robots.
Unread 08-07-2016, 23:00
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
They used it everywhere! Most of the mechanisms on their robot were powered by polycord. It was cool to look at, and obviously functional.
Unread 08-07-2016, 23:16
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
A quick skim of the 20 pages of search results for chain vs belt gave me these:
https://www.chiefdelphi.com/forums/s...=Chain+vs+belt
Unread 08-07-2016, 23:20
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
My FTC team is looking at it as complete replacement for gears and chain.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 09-07-2016, 00:06
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
I wouldn't trust it in high torque situations such as drivetrains, as I haven't worked with it yet. If anybody can speak to polycord's power transfer ability before slipping that'd be awesome. I can't wait to test the stuff in many different applications.
Unread 09-07-2016, 00:07
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Thanks, Drew
It could just come down to what your team already has or is familiar with. CD has no consensus on whether belts or chains are better. So, I just use chains because that's what the team already has.
Unread 09-07-2016, 00:16
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Whatever you choose, make sure you have good alignment. We had a regional last year where we broke about nine belts because of poor/weird alignment. We also had to disassemble the third stage of our gearboxes for at least six of those belts, so we basically got so sick of replacing belts that we went with #25 chain this year. But again, alignment.
Also, be sure you can tension your chain because it will stretch.
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
Unread 09-07-2016, 02:09
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
I like belts for everything other than drivetrain. Why drivetrain? Because for a given strength, chain is more compact than belts, and with the 4-cim loads in the drivetrain compactness is a high priority for me. That's a point that's often overlooked in the belts vs. chain debate.
It's also possible to run chain in tube in a 2x1 easily and reliably, whereas doing the same with belt is a lot harder.
Belts run quieter than chains, so for anything else- from shooters to intake to arms- I prefer them. In the specific case of arms, the belt will likely slip before the gears start shearing teeth (in theory), so I get a bit of a safety factor there.
Unread 09-07-2016, 09:42
ASD20's Avatar
AKA: Andrew
We tried using it this year for driving our intake. Our intake was designed to pinch the ball between the wheels and a churro and we could not spin the ball out. The polycord would just slip. We were attempting to use it more like a traditional belt, which was probably our mistake, and only had 2 cords. However, in 2015 we used it for a conveyor belt and it worked fine. I think the main dlfference is we had a lot more cords (4 or 5) and it was a lower torque application.
