pic: ABS-122, shifter-in-tube chassis
Re: pic: ABS-122, shifter-in-tube chassis
It doesn't look like you have any form of chain tensioners on this setup. Although you can do without them, I would still really recommend putting them on even in the case of using large tooth count sprockets. We used a setup similar to this in terms of chain, and really wished we had designed a way to tension the chain during the season.
![]() With massive sprockets such as these I'm not as worried about the chain coming off as much as I am about the chain picking up tape. I could swap these out for #35 chain sprockets, but the extra weight isn't worth it to me. In-season if it became a problem switching to #35 chain would be my first choice.Last edited by asid61 : 10-07-2016 at 20:11. |
I'm really impressed with how compact this is. What size are those sprockets, by the way? I think you'll be fine leaving it at exact C-C, but since the chain is outside of your tube, it'd be easy to add a static tensioner after your first or second competition. Just for peace of mind you might want to print something that fits around or on the top of your motors to ensure the chain doesn't rub against the motors in the worst situations.
The sprockets are 38 tooth versasprockets from Vex with a minor diameter of just over 2.8". They are inline with the CIMs, so I'm not too worried about the chain hitting. In the past 115 has used polycarbonate chain guards, so if there was a problem I would stick those in. |
I like this. I think it would also be a neat way to do a single speed drive with a PTO, not super clunky like most PTO setups.
#7
I was thinking about making a PTO option of this. With the Versadog it becomes a lot easier too.
#8
We never had issues with it slipping or jumping or breaking or ever coming off. We just find it very hard to write fast, accurate and repeatable autonomous modes with so much slack in our chain. It gives semi un repeatable results in our vision code when only the front 2 wheels move while the back 4 don't having to make up the distance in chain slack. It would have been much better to just run tensionors from the start.
#9
How did it cause errors/to what extent? If two wheels are moving, theoretically the whole bot should move anyway. Would direct driving the center wheel help? |
#10
On the other hand, if 60% of my robot's weight were on the front wheels in a static configuration (and presuming I had at least six wheels), I would be VERY worried about the robot falling on its face in a braking maneuver. |
#12
That is completely dependent on CG height and, given 4587's short robot, probably not a major risk.
#13
With this being said. After 2 regionals, Champs, and an offseason already we never replaced 35 chain, or 25 chain. We were never worried about it breaking either. It is just something that doesn't occur that often if chain is used correctly, which we did, just without tensioners. Which in our case worked very, very, very well, and in many cases would be fine for most every other team in FRC not wanting to do some of the precision complex things things we need to get our code really dialed in. |
#14
Looking at the size of those tubes, would you be able to put the wheels inside them to maximize space used in the tubes? That would also allow you to move your side rails out more to create more space in the center of the frame.
#15
The two wheels directly driven by the gearbox have to be outside the tube as the gearbox is inside the tube already there. The other wheels could be put inside the tube, but that doesn't really do anything for you.
