Re: pic: ABS-122, shifter-in-tube chassis
I like this. I think it would also be a neat way to do a single speed drive with a PTO, not super clunky like most PTO setups.
I was thinking about making a PTO option of this. With the Versadog it becomes a lot easier too.
We never had issues with it slipping or jumping or breaking or ever coming off. We just find it very hard to write fast, accurate and repeatable autonomous modes with so much slack in our chain. It gives semi un repeatable results in our vision code when only the front 2 wheels move while the back 4 don't having to make up the distance in chain slack. It would have been much better to just run tensionors from the start.
How did it cause errors/to what extent? If two wheels are moving, theoretically the whole bot should move anyway. Would direct driving the center wheel help? |
On the other hand, if 60% of my robot's weight were on the front wheels in a static configuration (and presuming I had at least six wheels), I would be VERY worried about the robot falling on its face in a braking maneuver. |
#7
That is completely dependent on CG height and, given 4587's short robot, probably not a major risk.
#8
The back wheels are solely used on defenses. Happy we didn't go 4 wheel.
#12
Having un-powered wheels in your drive train is generally not a good idea. They create friction and make it really, really hard to turn. Replacing them with a caster or some low friction nylon for example, is also not a great idea because this year our back wheels help us get over defenses, and when you put something in place of a wheel that doesn't roll, and hit defenses as hard as we do, it won't turn out so well. Removing wheels and just replacing them would not be as good as just designing a drive train with 4 wheels only. In cases like this year, we needed 6 wheels to not get stuck on defenses so that's what we went with.
When it comes to drive trains we go with something we are confident with. 6wd and 8wd are types we've worked with before and have given great repeatable results. Adding furniture sliders or caster wheels to our drivetrain is probably something we will never consider doing on our drivetrain. |
#13
To OP:
I recognize that this is a mostly theoretical drive train but have you thought about how you would remove a CIM, if it were necessary? |
#14
It looks like he oriented the motors in a way that you can access the bolts around the gears. But I am just assuming so I could be wrong.
#15
I actually added a lightening pattern later such that a ball end allen key can access the bolts to remove the CIMs. As it stands right now, removing the gear in between the two CIMs would suffice to remove them.
