Go to Post At championship, as we do at every regional, we'll be counting every point scored (or lost) by each robot. Nothing beats numbers. - Derek Bessette [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
  #76   Spotlight this post!
Unread 06-04-2016, 19:36
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Re: Tower Tracker 1.0
and how to modify the code to use HSV instead of RGB?
  #77   Spotlight this post!
Unread 06-04-2016, 19:39
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Originally Posted by Woolly View Post
I would actually recommend doing your calibration in the HSB/HSV color space, as it separates color(H) from brightness(B/V) which means you can get a more robust calibration that will working in many different lighting environments (as the color your LEDs output shouldn't change) provided you turn your camera's exposure down.
That is true, but we didn't have any issues with RGB.
Also, those values seem fine to me. I think i see the issue. Tower Tracker checks if the goal bounding rectangle is wider than it is tall. So when viewing from sharp angles like that is not going to give you a selected contour. Do you have a test image where the goal is straight on? If not, you can just get rid of this segment of code:
float aspect = (float)rec.width/(float)rec.height;
if(aspect < 1.0)
    iterator.remove();
  #78   Spotlight this post!
Unread 06-04-2016, 20:23
axton900's Avatar
Rookie Year: 2015
Oh! Thanks so much! We were hoping to have this running by this Saturday for our competition!
  #79   Spotlight this post!
Unread 06-04-2016, 20:26
jreneew2's Avatar
AKA: Drew Williams
So it works? If so, good luck at competition. Any questions, PM me or post here.
  #80   Spotlight this post!
Unread 06-04-2016, 20:29
jreneew2's Avatar
AKA: Drew Williams
Sorry for double post but just making sure you see this...
I would also check for solidity of the target. This makes sure you don't get stray objects even if it passes all other checks. Here is c++ code, very similar to java.
float area = contourArea(contours[i]);
float hull_area = contourArea(hull);
float solidity = (float)area / hull_area;
if (aspect > 1 && rect.area() > 100 && (solidity >= .04 && solidity <= .4)) {
    selected.push_back(contours[i]);
  #81   Spotlight this post!
Unread 08-04-2016, 02:20
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
The aspect ratio part of the code helps filter out things that the hsv filter cannot. We know the target is always wider then it is tall therefor it's aspect ratio will always be greater then 1 and if it's not don't detect it as a possible target. There are other things you can do to help but my team has found its good enough. You always know it's going to be atleast a certain pixel range because you can only shoot from a certain part.
  #82   Spotlight this post!
Unread 08-04-2016, 07:02
jreneew2's Avatar
AKA: Drew Williams
Yes that is a good idea, however I knew axton would have trouble with that section of code. So he should add it in later once he gets better pictures of the goals.
I also added checks for solidity in my c++ version here if you want to check it out. Just like in grip.
  #83   Spotlight this post!
Unread 08-04-2016, 08:56
axton900's Avatar
Rookie Year: 2015
Yes! It turned out that the bounds are in HSV and not RGB and that solved some problems. I am hoping to get some good pics during field calibration today for the our event and calibrate correctly! Thanks guys for all the help!
  #84   Spotlight this post!
Unread 09-04-2016, 02:53
Head programmer
if you need to you can save images every x amount of frames and write them to the driverstation laptop. My team did that during the match to see if we had the values correct (which we did). Sometimes fta is rude about measurement sometimes they are nice.
  #85   Spotlight this post!
Unread 14-04-2016, 10:46
Mr. Rick Mr. Rick is offline
FRC #5407 (Wolf Pack Robotics)
Rookie Year: 2015
Mr. Rick is an unknown quantity at this point
Team 3019 graciously presents their vision tracking program for everybody to use and borrow! Now instead of dreaming about the perils of computer vision YOU can bring your team the joy of having a robot that is capable of tracking the target with ease! No more Grip crashes or weird deploys, can calculate fun things such as: distance to target, and angle to target! to be used to auto align and auto aim!
if you are going to modify the code, all i ask is give me and my team credit in a comment at the top of the code and comment your suggestions and or your praise!
to install:
  • download opencv 3.1 from here
  • download Network table 3.0 jar
  • make a new project in eclipse
  • make opencv and networktables added as a user library to the build path of your new project
  • copy opencv_ffmpeg310_64.dll from C:\Path\to\opencv\build\bin to C:\Windows\System32
  • add the code in a class that is named TowerTracker.java
  • when your ready to export
  • export the .jar file as a runnable jar
  • move the .jar to a folder similar to this
  • run the .jar with "java -jar c:\Path\to\TowerTracker.jar" on a command prompt window
the code is just an example of what it can do, i can add network table stuff soon but i thought i would publish it first!
github link
want to see an example of what it can output?
here you go!
how it works: using an axis camera or a mjpeg streamer you can use a stream of a webcam to process images using an opencv program that runs on the driver station computer. This program can be modified to run on a coprocessor and directly input to the roborio for even better results because network tables can only go at 10hz vs the camera stream which is 30hz...this program can easily be ported over to c++ and python and would probably run better with those as c++ and python are way more supported then java with opencv.
Fauge7, thanks so much for taking the time to write this out! We are trying to use your solution but there are a few errors in your github code. I fixed a couple of them (for example, line 87 and a few merge artifacts left over near the bottom), but I'm still getting the following error when running the jar file in the command line:
Exception in thread "main" java.lang.NullPointerException at org.usfirst.frc.team5407.robot.TowerTracker.main(TowerTracker.java:107)
We are totally new to java, or any language for that matter. Does anyone have working java code they would be willing to share?? Thanks!
  #86   Spotlight this post!
Unread 21-04-2016, 18:48
Head programmer
Yes, I messed up the github code but luckly one of my team members has the code on his github. https://github.com/Aventek/TowerTracker3019Modified
Hopefully this helps, pm me if you have any questions!
Engineering Inspiration - 3019
Tower Tracker author (2016)
  • 1 regional finalist
  • 1 regional winner
  • 3 innovation in control awards
  #87   Spotlight this post!
Unread 11-07-2016, 01:17
E, Palmer E, Palmer is offline
FRC #6239 (The Irrational Engineers)
E, Palmer will become famous soon enoughE, Palmer will become famous soon enough
This may be a dumb question. But could someone please explain to me the "fun" math i am not really sure how its doing what it is doing.....
  #88   Spotlight this post!
Unread 11-07-2016, 12:12
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
I can try
y = rec.br().y + rec.height / 2;
y= -((2 * (y / matOriginal.height())) - 1);
These two lines are a bit confusing (lesson to be learned here: don't write spaghetti code in a public code demo ). Let's rearrange the operations
double half_image_height = matOriginal.height() / 2;
double pixel_y = half_image_height - (rec.br().y + rec.height / 2);
y = pixel_y / half_image_height;
Unless I'm missing something (which is likely), this doesn't seem quite right. Notice the rec.br().y+rec.height()/2. I would change that to rec.br().y-rec.height()/2 so it finds the middle y-coordinate of the bounding rectangle.
With that change, this operation makes a bit more sense. The point is to calculate the offset in normalized coordinates from the middle of the target to the horizon. The horizon is assumed to be at (matOriginal.height()/2). First, it subtracts the y-coordinate of the middle of the target from half of the image size in pixels. This results in the pixel offset between the horizon line on the image to the target y-coordinate. Then, the entire thing is normalized by dividing it by half the pixel image height.
distance = (TOP_TARGET_HEIGHT - TOP_CAMERA_HEIGHT) / Math.tan((y * VERTICAL_FOV / 2.0 + CAMERA_ANGLE) * Math.PI / 180);
This section is more clear right off the bat.
There are two parts. First, the angle from the horizon to the target is approximated using the small angle approximation.
The small angle approximation states that sin(x) = x for small values of x (in radians; in practice anything up to about 30 degrees), so they used linear scaling to calculate the angle rather than the more precise
angle = arcsin( pixel_y * sin(VERTICAL_FOV/2.0) / half_image_height )
(Remember that y is actually pixel_y/half_image_height)
Now the camera may be tilted relative to the field, meaning that its local "horizon" isn't the same, so the offset CAMERA_ANGLE is added, for the angle that the camera is tilted relative to the actual horizon.
Now the final part is to calculate the distance using the known height of the target and this calculated angle to the horizon.
h is the distance from the camera's height to the target's height (TOP_TARGET_HEIGHT - TOP_CAMERA_HEIGHT), so tan(alpha) = h/d => d = h/tan(alpha)
I hope this explains it.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
  #89   Spotlight this post!
Unread 17-07-2016, 01:37
I am very likely working on a faulty understanding of FOV but wouldn't this be much simpler?
double AngleToHalfScreen = Vertical_FOV/2;
        double OffsetFromMiddle = Math.abs(targetY - pixelHeight/2);
        double FractionofOffset = OffsetFromMiddle/(pixelHeight/2);
        FinalAngle =  AngleToHalfScreen+(AngleToHalfScreen*FractionofOffset);
This is way to simple to be right.
Thank you so much for taking the time to explain this.
