Go to Post My students like to win, so I'll stick to enabling that. - sdcantrell56 [more]
Unread 09-07-2016, 12:04
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: Chain vs. Belts?!?
Originally Posted by Sperkowsky View Post
iirc belts actually are more sensitive to being out of alignment so switching to belts is only going to make things worse.
QFT.
If alignment or tolerance is what is causing you problems now, switching to belts will make the situation much worse.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 11-07-2016, 14:05
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
We successfully used a Polycord drive system in the past. One of the center wheels was direct driven by a custom super shifter based gearbox. The other wheels are all direct driven by Polycord using custom pulleys directly attached to the wheels (Dead Axles). This is the best picture I could find of the drive train. (This is one of our signature Round Robots)
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 11-07-2016, 14:17
ASD20's Avatar
ASD20 ASD20 is online now
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Attachment 20906
Out of curiosity, what year was it? Also, did you have any problems with the polycord slipping in shoving matches or other high-torque situations?
Unread 11-07-2016, 14:22
Michael Hill's Avatar
There's no single correct answer (despite what some CDers would say) of what you should use. It all depends on your situation. If you need the weight, you may need to go with belt. If it's going to be a giant PITA to change a belt, you may need to go with a chain.
In my opinion, the "default" choice, when nothing really matters, you just need a reliable drivetrain, is to go with #35. It doesn't break, it's dead simple, it's forgiving, but is heavy. However, the "nothing really matters" portion is rarely the case and each situation needs to be handled on a case-by-case basis. What is important is knowing the tradeoffs (which have been outlined pretty well already in this thread). I wouldn't, however, deviate from the "default" of #35 chain without a good reason. The good reason may be weight related or space related, but you should at least have one.
Unread 11-07-2016, 14:35
ASD20's Avatar
AKA: Andrew
Agreed. My team has learned the hard way to just use #35. The way I like to think about it is that #35 is complete overkill for FRC, which is why its the best option for FRC. Since it is overkill, it is a lot harder to mess up and will just work, which is exactly what you want for a drive train. The question you should be asking whenever you use chain should be why should I use #25, not why should I use #35.
Unread 11-07-2016, 14:42
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Belt and chain weight is the same when you factor in pulleys/sprockets. That being said I 100% agree that #35 is bulltproof and should be used for a "first chassis" sort of deal.
Unread 11-07-2016, 15:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Assuming you are using aluminum pulleys, the pulley/sprocket weight is probably close to a wash. Factor in 35 chain, the chain is a lot heavier.
Polycord will slip given enough torque. That is either a bug or a feature depending on your needs.
Unread 11-07-2016, 16:12
InFlight's Avatar
AKA: Jim
That was the 2014 season, Our Jupiter Robot. No real noticeable issues with belt slip.
Here a match from that season with plenty of pushing.
http://www.thebluealliance.com/match/2014pncmp_qm41
Unread 11-07-2016, 16:17
ASD20's Avatar
AKA: Andrew
Wow, I never would have thought that polycord would work in a year like 2014. I'm impressed.
Unread 11-07-2016, 16:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I was thinking about #25. For #35 nothing beats it in terms of weight.
EDIT: InFlight, that is a gorgeous robot and a great performance! I can't believe polycord drive worked that well.
Unread 11-07-2016, 18:47
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Our team has used #35 chain with no master links for the past 3 years. Before that we used belts one year and did some direct drive from the gear boxes before that. Personally i dont see us ever moving away from #35 chain. We have never had a problems with it while i have been on the team, however i think that our first year we did break a few chains dew to improperly installing the master links. Since then we just haven't used master links and it works very well.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
Unread 11-07-2016, 19:29
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
How do you avoid using masterlinks? Do you have a #35 chain tool like the Dark Soul one for #25?
Unread 11-07-2016, 20:44
FRC #1836 (MilkenKnights)
This year my team's robot had 8" wheels and 22t sprockets, which stressed #25 chain more than in any of our previous drivetrains, and had zero issues. On the other hand, we broke our #25 intake arm chains multiple times, and in the future we will likely use #35 chain for arm applications. At least for our team, we have found applications for both #25 and #35 chain.
Unread 11-07-2016, 20:54
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
DrewMatic is an unknown quantity at this point
Where would you go about getting a dark soul for #25. Our team needs one.
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 11-07-2016, 20:58
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
221 Robotic Systems recommends here.
