Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
  #31   Spotlight this post!
Unread 11-07-2016, 21:05
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: Chain vs. Belts?!?
Originally Posted by DrewMatic View Post
Where would you go about getting a dark soul for #25. Our team needs one.
Originally Posted by Greg Woelki View Post
221 Robotic Systems recommends here.
I bought one from Dave's motors earlier this afternoon and it shipped only a couple hours later. So far they seem to be a good supplier, and they take PayPal which is nice.
  #32   Spotlight this post!
Unread 11-07-2016, 21:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Ditto here. I've bought two from DDM. (Get a spare set of pins when you do; I'm not sure how long they last after you know how to use them, but we had one break under first time handling by a student on Saturday.)
A similar tool for #35 is available here. As it happens, I'll be ordering a couple this evening, so I can't make a recommendation.
Edit:
For the record, the Dark Soul tool requires slightly different usage for standard duty vs heavy duty (e.g. Vex, and I believe also AM) chains. The difference between the two is the "plate thickness", that is, the thickness of both the inner and outer plates that run from pin to pin. For heavy duty chain, when removing a pin, it is necessary to go to the point of increased resistance, then about another 1/4 turn. For regular duty chain, doing this will result in the pin being pushed completely out of the outer plate, making it essentially impossible to use that link again, at least by using the DS tool.
Also, take care not to over-tighten on pushing pins into the chain; stop just before the screw pin reaches the outer plate of the chain. Even when doing this, I have found it necessary at times to use a screwdriver of just the right width and a hammer to push the outer plates away so that they do not bind on the inner plates -- especially when using standard-duty link-and-a-halves.
OBTW, does anyone know where to source a heavy duty #25 link-and-a-half?
Originally Posted by Cothron Theiss View Post
I'd love to hear how these tools perform. I want my team to get away fro Master Links in #35 chain, so just some info about how well it works would be greatly appreciated.
The order is placed. I'll try to remember to post some info back here in a few weeks. If not, send me a PM around 1 August to remind me!
Edit 2:
Originally Posted by Chak View Post
We bought that exact chain tool from Amazon for this build season. It works, and it does the job, but the quality is not the best. One of the bolts had a hex socket that was ever so slightly too small, and I had to widen it by pounding the 3/8" hex key in and shaving off a thin layer of metal off the bolt. No other hex key, in mm or inches, was as close to fitting as the 3/8" - which works perfectly fine for the other bolt. I was probably just unlucky, but that's still bad quality.
On the first tool we ordered (all I've had in hand so far), the pins were driven perfectly by 5/32" allen wrenches. That was already our most-used hand tool*, so I just bought a couple more!
* - I even have one on my non-car key ring - not only for use on robot stuff, but the "crash door hardware" at the school and church both use 5/32" hex keys to place the hardware in and out of "access from outside" mode. I pretty literally never go more than 50' from my house without a 5/32" allen key in my right pocket.
I did notice some online directions for using the Dark Soul tool referencing a millimeter-based tool (4mm, IIRC).
  #33   Spotlight this post!
Unread 11-07-2016, 21:53
lark95's Avatar
lark95 lark95 is offline
Red Ranger
AKA: Joe L.
FRC #3418 (RoboRiot)
Team Role: Driver
lark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of lightlark95 is a glorious beacon of light
Originally Posted by asid61 View Post
How do you avoid using masterlinks? Do you have a #35 chain tool like the Dark Soul one for #25?
While we do have a few hand held chain breakers, what we use most is a custom press pin we made to mount right to a small bench top arbor that we have. On the face of the press there is a piece of steel with holes drilled to align the chain under the pin and then we just press out one of the pins so it is just in one side of the link. Then remove however links we need to and flip the chain and press the pin back in.
FRC Rebound Rumble | Ultimate Ascent | Aerial Assist | Recycle Rush | FIRST Stronghold | FIRST STEAMWORKS
FLL Senior Solutions | Nature's Fury | Trash Treck | Animal Allies
  #34   Spotlight this post!
Unread 11-07-2016, 21:58
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
I would be really interested in seeing some pictures of this. This sounds amazing, and a clever piece of engineering.
  #35   Spotlight this post!
Unread 11-07-2016, 22:01
lark95's Avatar
Red Ranger
AKA: Joe L.
Team Role: Driver
I will try to get some picture in the next few days. It has done wonders for making chain lengths for us.
  #36   Spotlight this post!
Unread 11-07-2016, 22:07
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
  #37   Spotlight this post!
Unread 12-07-2016, 08:29
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Hey everyone. I'm from team 240 T.E.M.P.E.S.T.
The past 2 years we have used chain everywhere. There was one thing that happened, we had to fix the chain a lot more than we liked too. I know this could be due to poor alignment, etc. but next year we plan on using belts.
What are your thoughts on Chains? Belts?
Thanks, Drew
Both chain and belt are legitimate forms of power transfer and can be used successfully with proper implementation.
My personal preference is chain for low speed high torque applications, such as drive. Chain takes up much less space than an belt with the same strength. IMO chain has more reliability and strength in a smaller package, with less efficiency and more weight than belts.
Belts for high speed low torque application, the gains in efficiency are noticeable over chain. Also, belt for long runs for weight reduction.
The beauty is there is no right or wrong answer, there just has to be consideration for the down selection and performance desired.
  #38   Spotlight this post!
Unread 12-07-2016, 08:42
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
We have been using this little guy for years now and it performs very well. It can be a small hassle to get the new pin to line up properly with the holes in the chain as you tighten down the screw, but isn't as bad as installing a masterlink. Like everything, doing it with the chain untensioned is going to make your life easier, but we have had success even with chain lengths that are technically too short for where we are using them.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
  #39   Spotlight this post!
Unread 12-07-2016, 09:10
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We have a chain tool that looks just like that Gee Two linked to. I think we bought from the same place some years ago based on CD recommendation. Works great. The guides line up the chain and help to hold it in place. Assembling/breaking chain takes a bit of technique. Easily learned through practice.
We have also found this tool useful for putting master links on chains.
For those considering poly cord for drive train, keep in mind that one wheel per side on Inflight's nicely done robot was direct driven from the gear box which plays into how much torque needs to get transmitted to the other wheels by the poly cord. The pulleys for the poly cord where also large which helps with the force transfer.
  #40   Spotlight this post!
Unread 12-07-2016, 09:18
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
I can attest that that tool is approximately 5-10 times faster to use than the one-size-fits-all spring-loaded chain breaker.
  #41   Spotlight this post!
Unread 12-07-2016, 10:44
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Which tool? This links to the "chain tools" page on McMaster
  #42   Spotlight this post!
Unread 12-07-2016, 12:16
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
My apologies. This tool
Which should be a roller style chain holder. It holds the chain together so you are not trying to put the master link in with the chain in tension.
  #43   Spotlight this post!
Unread 12-07-2016, 13:59
Thanks for the recommendations! My mentor asked me to find what tools/equipment We needed to look at buying for next year, and at around $15, I think that will be the first tool on the list.
  #44   Spotlight this post!
Unread 12-07-2016, 14:19
ASD20's Avatar
AKA: Andrew
I would get both that and a dark soul because you will most likely use both #25 and #35 and trust me, if you use it just once, you will feel you got your money's worth.
  #45   Spotlight this post!
Unread 12-07-2016, 14:35
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Chain vs. Belts?!?
If you are looking to buy a #25 chain breaker this thread (https://www.chiefdelphi.com/forums/s...d.php?t=143362) has some good suggestions. I would absolutely stay away from one of those "one size fits all" spring loaded models. We have one and it is absolute garbage. Instead of pushing the pin out, it just bends and destroys the chain side plates. We were able to mess with it enough to break the chain for our shooter this year but it was a nightmare.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
