Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 12-07-2016, 21:28
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: pic: ABS-122, shifter-in-tube chassis
Originally Posted by chrisfl View Post
Looking at the size of those tubes, would you be able to put the wheels inside them to maximize space used in the tubes? That would also allow you to move your side rails out more to create more space in the center of the frame.
You know, now that you have the gearbox AND the wheels in that tube . . . you could probably get the RoboRio and the VRM in there if you get creative . . .
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 12-07-2016, 21:44
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
How to Give Electrical a Heart Attack, part 3
Unread 12-07-2016, 21:56
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
I do electrical, +10000000000
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 12-07-2016, 23:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by GeeTwo View Post
On the other hand, if 60% of my robot's weight were on the front wheels in a static configuration (and presuming I had at least six wheels), I would be VERY worried about the robot falling on its face in a braking maneuver.
Originally Posted by MichaelBick View Post
That is completely dependent on CG height and, given 4587's short robot, probably not a major risk.
I know it sounds strange, but if this is the case, I would seriously consider not driving the back wheels at all -- save the chain and sprockets and heartache. I might even consider skipping the back wheels and putting some pegs or furniture gliders. Here's why: If 60% of the weight is on the front wheels, the CoG is closer to the front wheels than the middle wheels. If the CoG is low enough that you are "not at major risk" of braking hard enough to tip forward, you are probably "at minimal risk" of ever needing to put weight on the rear wheels, and at "fuggetaboudit" for need to drive those rear wheels.
Unread 13-07-2016, 00:45
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Interesting idea. From what I can tell, unpowered wheels used to be more common on early FRC drivetrains, but have fallen out of style in the past several years. It would probably work well in this case, but I do see one thing that might be a concern. In a six-wheel drop center (which might or might not be what we're talking about, I don't know 4587's robot), doesn't the robot tip backwards onto the back four wheels when driving forwards? Now I know that the position of the center of gravity affects the tilting of the chassis, but this would be on a case by case basis. If the chassis DOES tilt backwards when driving forwards, not powering the back wheels may make acceleration quite slow.
Unread 13-07-2016, 01:13
FRC #1836 (MilkenKnights)
The major issue with this (for my team) is pushing matches: for example, during forward pushing you can easily have 100% weight on the back two wheels.
Unread 13-07-2016, 01:27
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
FRC #4587 (Jersey Voltage)
Clayton Summerall is on a distinguished road
The back wheels are solely used on defenses. Happy we didn't go 4 wheel.
Unread 13-07-2016, 02:15
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Having un-powered wheels in your drive train is generally not a good idea. They create friction and make it really, really hard to turn. Replacing them with a caster or some low friction nylon for example, is also not a great idea because this year our back wheels help us get over defenses, and when you put something in place of a wheel that doesn't roll, and hit defenses as hard as we do, it won't turn out so well. Removing wheels and just replacing them would not be as good as just designing a drive train with 4 wheels only. In cases like this year, we needed 6 wheels to not get stuck on defenses so that's what we went with.
When it comes to drive trains we go with something we are confident with. 6wd and 8wd are types we've worked with before and have given great repeatable results. Adding furniture sliders or caster wheels to our drivetrain is probably something we will never consider doing on our drivetrain.
Unread 13-07-2016, 02:17
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
To OP:
I recognize that this is a mostly theoretical drive train but have you thought about how you would remove a CIM, if it were necessary?
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 13-07-2016, 02:34
Cash4587's Avatar
AKA: Cooper Cash
Originally Posted by Bryce2471 View Post
To OP:
It looks like he oriented the motors in a way that you can access the bolts around the gears. But I am just assuming so I could be wrong.
Unread 13-07-2016, 02:40
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
To OP:
I actually added a lightening pattern later such that a ball end allen key can access the bolts to remove the CIMs. As it stands right now, removing the gear in between the two CIMs would suffice to remove them.
Unread 13-07-2016, 02:48
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I guess the question I was trying to get at is: How would you remove the idler gear with the bearing flanges to the inside of the tube?
Unread 13-07-2016, 03:22
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Good point. That raises the other question: how would the shaft get in there to begin with?
The lightening holes might let you get away with not removing the gear. But IRL if I made this, all bearing flanges would be on the outside and/or I would use riveted bearing blocks to save space inside the tube. That particular spot is actually easy to put at least one of the bearings on the outside because I have space in there.
