Go to Post We were all rookies once, and we really have two ways to go about things: either take a page from the powerhouses and emulate their style, or complain about not having anything and risk falling into oblivion. - George A. [more]
Unread 13-07-2016, 03:34
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Re: pic: Everything in the tube drive (too late to turn back now)
Originally Posted by Bryce2471 View Post
Thanks, and yes I prefer that to a lightening pattern.
Have you ever used this technique in real life? Even if you have a facing cutter and a good size mill it would take a huge amount of time and resources. The same result could be achieved by bolting/riveting/epoxying/welding a reinforcement plate in the areas you need on some thinner wall tubing.
In general when working with square tubing it's a better use of resources to order a smaller size/wall thickness than to machine weight away from a thicker tube.
Unread 13-07-2016, 15:10
Chris is me's Avatar
AKA: Pinecone
Could I get a picture of your shifter shaft without any gears on it? Kind of curious how that works out, with the pulleys on either end and the shifter in the middle.
Unread 13-07-2016, 18:24
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Yes, I have done this in real life. Admittedly to a tube smaller than the one pictured, but it did not take a lot of time or resources to do. Thinning the walls of the tube would be significantly stronger than bolting/riveting/epoxying/welding a reinforcement plate on, and would require less time and resources, because each side of the tube would have to be set up on a mill anyway.
Yeah... I wasn't able to come up with a solution that I really liked, but this is whats in the model:Picture
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 13-07-2016, 19:27
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Would you be able to put your front and back wheels inside the rails as well? That would utilize more space in them and maybe make the concept more valuable with as much space as possible being utilized
1991 2015-present
Unread 13-07-2016, 21:12
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Great idea! I'm surprised I hadn't thought of that. I still don't think the design would have enough value to be worth pursuing, but putting the wheels in there definitely saves some space.
Here's the updated model:Picture
Unread 13-07-2016, 23:21
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Thumbs up Re: pic: Everything in the tube drive (too late to turn back now)
Now, what would it take to get the motors inside the tube? They are fairly high on the list of components that get in the way, so that should be a priority. (2.5" motors fit in 2" tubes, right?)
1.25*sin(x)=1
sin(x)=0.8
x=arcsin(0.8)
L=1-1.25cos(x)    //maximum length of remaining material (in inches), measured from
L=0.25            //edge of tube, assuming motor is centered
(Yes, they technically do.)
Unread 15-07-2016, 11:53
FRC #1991 (Dragons)
1.25*sin(x)=1
sin(x)=0.8
x=arcsin(0.8)
If you are really ambitious, I bet a few talons could fit in there too! Maybe an accumulator even.
1991 2015-present
Unread 15-07-2016, 22:10
AKA: Alan Wells
FRC #1350 (Rambots)
While there are some that would fit, I think it would be more practical to keep the accumulators elsewhere. /S
On a slightly more serious note, there is still unused space in the front and back rails for possible manipulator or slide drive mechanisms.
Last edited by PAR_WIG1350 : 15-07-2016 at 22:18. Reason: More to say, didn't want to make consecutive posts
Unread 18-07-2016, 16:17
FRC #1991 (Dragons)
That would be a cool concept. A drop down slide drive with a full 6w tank. That'd be the ultimate butterfly drive! Have 2 omni wheels on the front and back faced perpendicular to the 6w tank. It'd be super heavy and complex though.
1991 2015-present
