Go to Post Please stand up and be proud of who you are and what you believe in! - MattK [more]
Unread 13-07-2016, 08:21
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Re: Mcmasters Brake and Clutch Lining
The arm gearbox I designed for 649 utilized a piston-actuated piston brake. The material used as the friction material was urethane as opposed to the materials in the link you provided. From what I heard, the setup has endured quite well during the competition season.
Of course, you would need to consider piston force and other factors, but I guess this would be "something equivalent" to the Brake and Clutch lining. Personally, I would recommend urethane, me coming from a team with experience with it in such applications.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 25-07-2016, 05:52
ShIfTiNgBoT's Avatar
ShIfTiNgBoT ShIfTiNgBoT is offline
AKA: David
FRC #0649
ShIfTiNgBoT is an unknown quantity at this point
Smile Re: Mcmasters Brake and Clutch Lining
Just chiming in here to let you know. It's still working great even after many post-season events and demos. quite an impressive system you made there. The Urethane pads haven't worn at all because the aluminum plate stops the instant it's pushed into it.
