Go to Post FIRST is not the end...it is the beginning - Greg Needel [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 12-07-2016, 14:16
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Interrupts with RobotPy
I know interrupts work with RobotPy, since encoders and counters are covered.
How do I create an interrupt with RobotPy?
Say I have the ADIS16448 IMU that I would like to use the DataReady output for to call an ISR. And yes, I know what I'm doing probably won't work well. Python is probably too slow to handle real time interrupts.
Some example code would be great!
Thanks!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 12-07-2016, 15:31
Re: Interrupts with RobotPy
Encoders and counters do not use interrupts. They are polled by the FPGA.
Unread 13-07-2016, 00:06
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
What he said.
... I've never tried doing WPILib interrupts in python. They certainly won't do anything in the simulator, and chances are they *mostly* work on the real robot, but there are probably edge cases where you'll get a weird exception (this is how I2C/SPI was until I actually had some hardware to do testing with).
I would recommend finding some Java code and translating it into python, and then file bug reports on github when you find it doesn't work.
Unread 13-07-2016, 12:36
RyanN's Avatar
RyanN
I'll try to find some Java code then.
I'm guessing the FPGA has RTL for handling encoders and counters then. (It makes sense). I always forget the RoboRIO is half processor, half FPGA. I'm used to just processors.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 13-07-2016, 21:14
The Java roborio library for the adis16448 uses interrupts for the same purpose you want.
Unread 18-07-2016, 11:16
RyanN's Avatar
RyanN
Yep. I figured that one out.
Thanks!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
