Originally Posted by mlantry
After looking into different things can be done to make intake rollers I came across that many teams use surgical tubing on some kind of round stock. I am curious how in which teams make said rollers. Thanks
Make sure that whatever you are using as the base roller, such as a tube, is plugged at one of the ends. Attach your surgical tubing to an air hose nozzle using a zip tie or something. While blowing air(you will need to control pressure and flow) have a second person slowly push the tubing over the roller. Do not pull. Do not squeeze the tubing to tight if your hand is over the roller while pushing, it will turn into a balloon animal and pop.
