Go to Post On the other hand, if the tires were marked "NOT FOR FRISBEE SHOOTER USE" I'd be worried. - Ken Streeter [more]
Unread 13-07-2016, 16:46
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
How do you make surgical tubing roller
After looking into different things can be done to make intake rollers I came across that many teams use surgical tubing on some kind of round stock. I am curious how in which teams make said rollers. Thanks
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 13-07-2016, 16:56
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: How do you make surgical tubing roller
I think those are actually made of poly cord instead of surgical tubing, or at least the ones I've seen. There's something similar at the bottom of this page. Is that it? If so, I think the poly cord is just wrapped around rollers, at least one of which is driven by a motor.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 13-07-2016, 16:58
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
I think they just force the surgical tubing on with some alcohol.
More information there:
https://www.chiefdelphi.com/forums/s...51#post1426351
Unread 13-07-2016, 17:01
I'm back
AKA: Matthew Lantry
ment more like the roller 254 used to intake balls with this year and in past years
Matthew Lantry
Unread 13-07-2016, 17:10
Michael Hill's Avatar
We did a latex surgical tubing roller this year. Just a little bit of alcohol does it. A little goes a long way. The hardest part was trimming up the ends of the rubber without it sliding or looking like crap. To do that, we put the tube assembly in the lathe and very carefully trimmed the ends with a box cutter. Our intake was actually a 3-roller system with polycord running in grooves of the latex tubing (using #25 chain for power transmission), which fed right into our shooter.
Unread 13-07-2016, 19:25
RoboChair's Avatar
AKA: Devin Castellucci
Make sure that whatever you are using as the base roller, such as a tube, is plugged at one of the ends. Attach your surgical tubing to an air hose nozzle using a zip tie or something. While blowing air(you will need to control pressure and flow) have a second person slowly push the tubing over the roller. Do not pull. Do not squeeze the tubing to tight if your hand is over the roller while pushing, it will turn into a balloon animal and pop.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 13-07-2016, 19:37
We didn't need any air at all for ours. With the rubbing alcohol, it slipped on quite easily.
Unread 13-07-2016, 20:03
RoboChair's Avatar
We used the above process to put 1" ID 1.5" OD latex tubing over 1.25" OD aluminum tube for our intake this year. As soon as you let off the air it is incapable of even being persuaded to move by use of force alone, you either float it some more with air or cut it off. It is very nearly a permanent installation method.
Unread 13-07-2016, 23:14
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Wow, with a difference of .25 diameter I would have expected needing epoxy or something. We used Polyurethane tubing this year much closer in size to our roller and ended up needing epoxy.
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread 13-07-2016, 23:15
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We used compressed air and soap and water. That allowed it to slip over the aluminum tube.
Unread 13-07-2016, 23:18
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
+1 for this method.
Unread 14-07-2016, 15:07
RoboChair's Avatar
Not 0.25" over, 0.25" interference fit. 1 inch ID rubber tube onto 1.25" OD aluminum tube.
Unread 14-07-2016, 16:37
Monochron's Avatar
Engineering Mentor
Ah, my reading comprehension needs some work
Unread 14-07-2016, 16:42
FarmerJohn FarmerJohn is offline
Pre-Rookie team
AKA: John Reynolds
no team (Turlock Titans)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
FarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond reputeFarmerJohn has a reputation beyond repute
Did you find that this method changed the OD at all?
Unread 14-07-2016, 18:20
RoboChair's Avatar
It probably ended up between 1.625" and 1.700" OD overall, I'm not actually sure what it came out to. But it was for sure smaller than 1.75"
