Go to Post It's not a rendering mistake, it's a design challenge! - Eric Scheuing [more]
  #271   Spotlight this post!
Unread 06-07-2016, 15:17
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Re: California District Proposal
Originally Posted by Mr V View Post
In the Regional system FIRST owns the fields so scheduling around other events so that a field is available in the area is important, as well as the desire to allow teams to compete at 2 events if desired. You don't want two Regionals in the same general area to happen on the same weekend.
Same or adjacent weekends...Last year:
Week 3 UT
Week 4 CO; SAC
Week 5 ID; LV
Week 5* WCan
These events are the closest candidates for second events for teams in the intermountain west area.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
  #272   Spotlight this post!
Unread 06-07-2016, 15:18
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
To add to a few points...
This is what FIRST is talking about when they say that Districts are cheaper than Regionals. So putting on say 10 district events and a DCMP can cost about the same as putting on 2 Regionals. Note this does vary greatly because venue costs vary greatly as well.
This is one of the key things FiM has sought to address with districts in Michigan, by moving to High School venues, most if not all of the venue rental costs are eliminated (as many school do not charge for the use of the facilities), typically leaving only maintenance and staffing costs for custodial and security services. While these costs do also vary by venue, they are still, for the most part, orders of magnitude lower than the costs for a traditional regional venue.
Switching to the District System alleviates those stepped on toes since the fund raising is for the entire district instead of for what may be one of multiple Regionals which may have different RDs in a general geographic area. Note you will find that some districts events the host team may find a local sponsor to provide food, coffee, or bottled water for the volunteers.
Also not entirely true, FiM encourages districts to find local sponsorship for their events and will simply fill in any gaps in funding on an as-needed basis. Most events are geographically far enough away that they avoids overlap in requests for sponsorship, and because the costs are less, it makes more sense to seek out smaller sponsorships from smaller local businesses. Also by placing some of the burden of finding sponsors on the events, it causes district event planing committees to be more frugal with their money, further reducing costs (after all, what incentive do you have to cut costs if you know you're getting a blank check).
With the district system the "normal sized" District typically owns two fields and it is common for 2 events to happen the same weekend. Smaller districts like IN will only have one field and one event per weekend while FiM has 3 or more events per weekend and the corresponding number of fields.
In the case of Michigan, I believe FiM actually owns 1 or 2 fields and rents/borrows the rest from FIRST. This year we had 4 fields in use across the state, and going forwards FiM is already looking at the possibility of getting a 5th field to run 5 events on one weekend (from what I've heard anyways). That said, FiM handles all of the transportation from all of the fields, rather than paying for them to hauled around via Tractor Trailers every week.
  #273   Spotlight this post!
Unread 06-07-2016, 15:24
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
FiM owns 3 fields. Was looking to purchase the fourth. Still a year or two away from needing 5 fields, especially if inter district play will count for points.
We also have some very awesome people who like to drive big trucks around the state But some good scheduling can limit that. Multiple weekends in a row with west coast events, or northern Michigan events, etc.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
  #274   Spotlight this post!
Unread 06-07-2016, 15:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Out of curiosity, where do we have this problem? I dare say MN has some of the closest regionals around (the two in Duluth are in the same building, the two in Minneapolis are across the street from each other!, and those pairs are only a 2 hour drive apart), but we've never had those sorts of problems. Everyone involved is dedicated to making all 4 events work.
2016: Lake Superior WFFA
  #275   Spotlight this post!
Unread 06-07-2016, 16:32
cbale2000's Avatar
AKA: Chris Bale
Well I was close, anyways.
I work with some of the guys who put together the electrical boxes and breakers that come on the FiM trucks, and they had mentioned at one point that FiM had been interested in having a 5th set made, so we may have assumed there would soon be a 5th field.
On a side note,
I think I might be the only person I've seen on CD who's not for inter district play counting for points. IMO, there's a lot of benefit, from a teams perspective, in being able to compete at an event that does not count for points, allowing teams to gain practice or extra out of bag time prior to your in-district events. Granted it might be a bit of an advantage for teams who are financially better off or geographically close to other districts, but the same can be said for a team that would spend the money to attend a regional, which changing the rules for inter district play won't affect at all.
  #276   Spotlight this post!
Unread 06-07-2016, 16:47
DuPiMan DuPiMan is offline
2016-17 Captain & App Prog. Lead
AKA: Bryton
FRC #1678 (Citrus Circuits)
DuPiMan is a glorious beacon of lightDuPiMan is a glorious beacon of lightDuPiMan is a glorious beacon of lightDuPiMan is a glorious beacon of lightDuPiMan is a glorious beacon of lightDuPiMan is a glorious beacon of light
Smile Re: California District Proposal
Originally Posted by Rangel(kf7fdb) View Post
I would very much like to say thanks to you and everyone else who helped work on these documents.
+1
  #277   Spotlight this post!
Unread 06-07-2016, 16:48
ASD20's Avatar
ASD20 ASD20 is online now
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
On a side note,
I don't like the regional loophole to begin with, but if FIRST isn't going to change that, then I guess allowing the same with inter-district play at least sort of lowers the barrier for entry for it.
  #278   Spotlight this post!
Unread 13-07-2016, 13:06
Happy Birthday! jpetito jpetito is offline
jpetito
AKA: Joe Petito
FRC #1197 (TorBots)
jpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to beholdjpetito is a splendid one to behold
"Under the heading of 'How Should One Handle Assumptions:' "
"Perhaps more than anything else, the Walker spy case is a study in assumptions. Time and again, individuals made decisions based on assumptions that proved to be woefully incorrect. In many cases, these assumptions were based on nothing more than wishful thinking, or on the fact that it would be very convenient if certain things were true. There is little or no evidence that decision makers attempted to verify or falsify them, even when such an attempt would be easy to make.
...Another military truism is that successful planners must clearly distinguish between facts and assumptions. All real-world plans will require some assumptions, as information will never be perfect. However, a successful planner will then try to verify or falsify his assumptions, continuing to do so until successful--either proving the assumption true, making it into a fact, or proving it false. 3"
From chapter Educator Bias, in Ditching Shop Class; How Educators Feed the Achievement Gap
Author of: Ditching Shop Class; How Educators Feed the Achievement Gap, @ Barns&Noble.com
  #279   Spotlight this post!
Unread 13-07-2016, 14:10
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Hi Joe,
I suppose I don't understand what the above quote contributes to the discussion? Are you cautioning one person, a sub-set, or the group about making assumptions?
I've made a lot of assumptions in the California Districts Proposal, but I've also been fortunate to have many talented and generous individuals help me get data to verify or falsify those assumptions.
On that point...
I am hoping to release a Rev 2 of the California Districts Proposal this weekend! Updated budget figures, and other structural changes to make the proposal more friendly/compatible with FIRST HQ's goals for FIRST.
**NEEDED** If you are familiar with FRC team data sets and willing to help process some region/district-specific growth/retention rates over the past 10 years, or have analysis about district/regional growth/retention rates, please PM me! I'd like to have some additional figures/numbers to back up some additional theories being added to Proposal Rev 2.
Also, did Joe Ross calculate California District Points for 2016? I remember he calculated CA district points in past years.
Thanks everyone!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #280   Spotlight this post!
Unread 13-07-2016, 15:46
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Awesome! Really looking forward to seeing it.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #281   Spotlight this post!
Unread 13-07-2016, 18:07
jpetito
AKA: Joe Petito
FRC #1197 (TorBots)
Hi Michael-
Look forward to rev. 2. And again many thanks for the reflection on hard topics.
The thing on assumptions is for us to make plain what the difficulties are and how to solve them by getting as empirical as we can. As with the Walker spy case, many wished things to be so, assumed they were so, and got burned terribly. Don't mean to do the aspersion thing…
Others with more experience than I, who I respect greatly, with more hands on effort putting together FRC events are extremely leery of getting into a massive mess because some make assumptions about how easy it will be.
Joe
Slack Cutter
PS- The us above is all of us, me too!
  #282   Spotlight this post!
Unread 13-07-2016, 23:18
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
"Perhaps more than anything else, the Walker spy case is a study in assumptions. Time and again, individuals made decisions based on assumptions that proved to be woefully incorrect. In many cases, these assumptions were based on nothing more than wishful thinking, or on the fact that it would be very convenient if certain things were true. There is little or no evidence that decision makers attempted to verify or falsify them, even when such an attempt would be easy to make.......[/u]
It's hard to imagine that anyone involved in process is thinking "boy I hope I never have to double check our methods and assumption with the other people involved in California FRC".
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
  #283   Spotlight this post!
Unread 13-07-2016, 23:55
EricH EricH is online now
I think the point is more:
We need to remove assumptions as much as possible. We need more data. But where assumptions are necessary, we need to act on those as soon as possible as far as finding out if they're right or wrong.
What looks really good on paper may or may not actually look really good in practice, and what works in practice is rather more likely to actually work on paper, though maybe not as well in theory as what looks good on paper. Remember that ideal physics problems take place in frictionless vacuums, while real physics has to deal with too much (or too little) friction with all contacting surfaces.
One of the best "rookie" events that I've heard about (or attended) was the O.C. Regional. Kind of helped that they'd eliminated a lot of the assumptions the previous fall at an offseason event, by testing the regional layout--and that test had learned from the same event the previous fall. Sure, there were some new elements to work around--but at the same time, dealing with 5 assumptions can generally beat dealing with 10, 20, or 50!
  #284   Spotlight this post!
Unread 18-07-2016, 12:35
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Originally Posted by IKE View Post
Dealing with administration:
...snip...
On the negative:
We also have some 1 hit wonders. I think "floor damage" concerns are one of the primary causes for a venue to not want teams back, though you would have to talk to the FiM management for reasons they don't go back to a venue. I know at least a few of them were dealing with floor damage concerns. Though that is not the only reason.
...snip...
I wanted to give an update on this. I got some additional info from someone with FiM who is heavily involved with venue coordination:
Of all the events, I have been informed that only 3 had some actual form of floor damage, and only one did not return (of which floor damage was not the only reason).
I do know it has been a concern and a point of discussion at a few events. For instance, at one event we had a team cart that would tear slits in the tarps when turning/maneuvering. This was a stressful item for a few hours while trying to find the "root cause", but ended up not being a big deal by the time the event ended. Overall though, floor damage has not been substantive reason for venues not returning.
I was given various reasons for venues not coming back with many tied to change in support level of those championing the event. Champions could be a school administrator or a FRC leader.
  #285   Spotlight this post!
Unread 18-07-2016, 17:35
Ike,
Thanks for the feedback on this. All of this experience sharing has really helped the conversation move forward.
All,
I apologize for not posting the Rev 2 of the CA Districts proposal this weekend. I am working to post the updated proposal on Wednesday.
I will say, I owe a huge thank you to many FRC community members from across the continent for their help in collecting and analyzing data for Rev 2. I am humbled and indebted by your support.
Again, apologies for the delay.
Best,
-Mike
