Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
  #31   Spotlight this post!
Unread 11-07-2016, 09:44
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: What is the strangest issue with a robot you have ever seen?
During one of our matches this year, we were the victim of a excessively hard autonomous. While our drivers caught the driver station, the lid on the laptop shut causing it to go to sleep. We ended up needing the FTA to bring over a spare driver station. After that we made sure that we disabled sleep mode on the driver station.
  #32   Spotlight this post!
Unread 11-07-2016, 09:49
Chris is me's Avatar
AKA: Pinecone
One team at one of our competitions had a very forceful appendage on a long swinging arm with a small point on the end, designed for drawbridge and stuff. It ended up swinging down directly onto the power cord of our radio, ripping the tape off and yanking it out. Fun.
  #33   Spotlight this post!
Unread 11-07-2016, 09:56
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
We ended up switching to C++ because in 2014 we were running labview, and its CPU would randomly max out then the robot would crash and you would have to cycle the power.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
  #34   Spotlight this post!
Unread 11-07-2016, 10:00
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
I had that too... Though if I clean my code it's fine.
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
  #35   Spotlight this post!
Unread 11-07-2016, 10:13
teslalab2's Avatar
RogueBotix LLC
VRC #8091
We had another programmer that knew labview and I told her she should let me try C++ and it fixed it. but yeah, Labview is the worst
  #36   Spotlight this post!
Unread 11-07-2016, 10:32
ShinyShips's Avatar
ShinyShips ShinyShips is offline
Former Operator and Captain
AKA: Andy
FRC #3314 (Mechanical Mustangs)
ShinyShips is on a distinguished road
Originally Posted by ollien View Post
Sounds like a combination of loose power cables on the Rio and on the radio. Seems a bit excessive to replace the Rio...
It may have been loose cables, but that was the first thing I checked when we got back to the pit. They all seemed fine. When we asked the FTA if he had any idea what happened, he didn't know. Better safe than sorry, really no harm in putting in a fresh rio after a season of 120+ matches.
  #37   Spotlight this post!
Unread 11-07-2016, 17:03
Best Available Data
FRC #1778 (Chill Out!)
2016, SCRRF Spring Scrimmage. 4276 goes just about 100% on finding the portcullis in autonomous. They were aiming for the rock wall, which happened to be next to it. They did eventually get that mostly worked out... but it did crop up about once an event after that.
I've also heard of an E-stopped robot continuing to wander slowly across the field. (This was over 10 years ago.) Seems the batteries were surface charging, and the controller had enough voltage to drive the motors--slowly--but not enough to read an E-stop signal from the radio.
In the original firmware for the 2007 modem there was a bug that could cause robots to "hold last value" and not see the E-Stop. We had modified the AM Shifters of the time to include a 3rd higher gear, and were testing them out on the shop floor of the vocational school we worked in. We had noticed some weird behavior, but we were just playing around and most of the driving was being done by students without much practice so we kept playing around.
There was a nice long straight away, with the auto workshop at the far end. We were zooming down the straight away when the driver noticed the robot wasn't responding... he hit the E-Stop about halfway down the straightaway, and the robot didn't stop. It continued until the top of the electronics board collided with the undercarriage of a truck in the auto workshop a few seconds later. The universe definitely conspired against us on this one, as the Victors on the electronics board were exactly at the right height to be "the impact zone", and since it was our prototyping electronics board we had 10 Victors on that board -- all of which were destroyed.
  #38   Spotlight this post!
Unread 11-07-2016, 17:22
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Does anyone remember the story of Harlem_Shake.vi?
  #39   Spotlight this post!
Unread 11-07-2016, 22:05
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
So last year, our lifting mechanism for the totes kept twitching up and down. This would happen whenever the bot was enabled, even when the controller wasn't connected. We calibrated the motor controller, but that didn't fix it. We went through the lifter code line by line and there was nothing there that could have caused the twitching. To this day, we still don't know what caused the twitching, but it doesn't matter because we cannibalized the control system for our 2016 bot .
  #40   Spotlight this post!
Unread 11-07-2016, 22:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not when it happened, but I have read about it through highlight posts. Two words: Price Less.
  #41   Spotlight this post!
Unread 11-07-2016, 23:24
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We've semi consistently had issues with motors "jerking" while the robot disabled with no one touching the driver station. I've been told it's impossible but it has happened multiple times on multiple robots.
2016: FRC 865 Mentor
  #42   Spotlight this post!
Unread 14-07-2016, 11:13
ceb515's Avatar
ceb515 ceb515 is offline
AKA: Charlie
FRC #2607 (Robovikings)
ceb515 is an unknown quantity at this point
In the build season of 2015, I had an interesting issue. We were testing an idea for a 6 wheel mecannum drive. It worked at first and then another programmer wanted to add PID loops. Lets just say when the RIO rebooted it ran full speed over my laptop. To this day my trusty laptop has some of its battle scars. (The screen and trackpad needed to be replaced, the frame of the laptop remains with gouges out of the aluminium.)
2015 - MAR Championship 3rd Place, Qualified for CMP
Blue Banners: 2010 Philadelphia Reigonal, 2014 Virginia Reigonal, 2015 Hatboro-Horsham, 2015 Upper Darby
SEE US AT THESE COMPETITONS:
Hatboro-Horsham District Event 2016, Westtown District Event 2016, MAR Reigonal 2016
Electrical Lead, Programmer, Designer, Pneumatics, Prototyping, All-Out-Geek
  #43   Spotlight this post!
Unread 14-07-2016, 17:28
Nightwing430's Avatar
Nightwing430 Nightwing430 is offline
Driver, Mechanic, I See Fire!!
AKA: Brittany
FRC #5679 (Girls on Fire)
Rookie Year: 2015
Nightwing430 is an unknown quantity at this point
For 2015 we were testing out our Auto and something happened and our robot started spazzing out and kept spinning around in circles, this only happened once and we don't know what really happened. Also with the same robot, sometimes when the arm mechanism is closed it starts twitching so we called it "hugging" now everytime it starts to twitch everyone says that all the robot wants is a hug.
  #44   Spotlight this post!
Unread 14-07-2016, 18:33
Connor McBride's Avatar
Connor McBride Connor McBride is offline
I live my life 2:30 at a time!
FRC #0166 (Chop Shop)
Connor McBride will become famous soon enough
Talking Re: What is the strangest issue with a robot you have ever seen?
Originally Posted by ShinyShips View Post
At BattleCry@WPI this year we were in the finals (Thanks 166!) against 195, 2791, and 501. Finals match 2, everything was fine until about 30 seconds into the match when we drove over the rock wall. Comms and robot code dropped, comms came back, but we were stuck without robot code for the rest of the match which sadly led to our defeat. RSL was solid I believe. After the match, we checked our 5v rail and it was fine and once we power cycled the problem was resolved.
Needless to say, we replaced our rio for IRI.
YOU'RE WELCOME!!!
FRC 166 2013-2016 (student) 2016-present (junior mentor)
NHTI VEX U 2016-present (treasurer)
Youtube Channel Team Page Facebook Page
  #45   Spotlight this post!
Unread 14-07-2016, 19:40
SpoonMechanic's Avatar
SpoonMechanic SpoonMechanic is offline
Build captain/Driver
AKA: TheSpoon
FRC #5549 (Gryphons.exe)
Rookie Year: 2015
SpoonMechanic is an unknown quantity at this point
That time the e-stop completely malfunctioned and a robot broke out in auto to terrify the front row. The robot uprising has begun.
