Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 15-07-2016, 13:32
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: pic: SERGE: Shirt-Ejecting Robot for General Entertainment
Originally Posted by Cothron Theiss View Post
Those look like Colson 4x2" wheels on the swerve modules? How well do Colson wheels perform on tile/concrete/asphalt/grass/gym floor?
Swerve on asphalt or grass is a little iffy to me. On a gym floor however these will preform fine and colsons are probably the best option for durability.
Unread 15-07-2016, 13:39
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Yeah, I'd say the wheels the OP chose are by far the best for the situation, but it's something to consider. Can the swerve capabilities be disabled for driving on certain terrains?
Unread 15-07-2016, 17:44
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
That would effectively turn it into a standard 4 wheel tank drive, which might actually be worse for turning due to the scrub it would induce than just staying with swerve enabled.
Unread 15-07-2016, 17:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
There are other possibilities - you could do an automotive or fire truck style steering setup, for example.
Unread 15-07-2016, 21:12
EricH EricH is online now
Depends a lot on wheelbase considerations... Looks like it's a square, or nearly so, so turning shouldn't be as bad as if it was a long-base. And there's always the possibility of a "spin-in-place" mode that would allow for quick turns.
Unread 15-07-2016, 21:21
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
You called?
Nice looking shirt bot!
Unread 15-07-2016, 22:55
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Regarding the corners...
I see you're using one big beefy 1/4" gusset (which is the swerve plate as well). I'm a little leary and would consider running another crossbracing underneath in the corners, to take torsion in the siderails better.. Unless you already have that? Hard to tell.
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://ppi.ddns.net/blog
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
