Go to Post Each year that I've been on the team I've thought to myself, "Man we lost some great seniors this year," and each year younger students have stepped up on their own to fill those leadership positions. - BJC [more]
Unread 14-07-2016, 13:36
cloudroth6 cloudroth6 is offline
FRC #4283
cloudroth6 is an unknown quantity at this point
What sensors do your teams use
So our team is looking at investing in more sensors and we were just wondering what other teams out there use.
Edit: We mostly use encoders, Gyros, Limit switch and distance sensors. but we are more wondering where other are getting senors for the past couple years we have been using Vex sensors because thats all we had.
Thank you for your time
Last edited by cloudroth6 : 14-07-2016 at 14:24. Reason: wanted to add more imformation
Unread 14-07-2016, 13:51
smitikshah's Avatar
smitikshah smitikshah is offline
Drive Coach
AKA: Smiti
FRC #2869 (Regal Eagles)
Rookie Year: 2015
smitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond repute
Re: What sensors do your teams use
Can you give a little more detail as to what type of sensors/what purpose you would want them for?
EDIT: (I probably can't help you, but rather I myself want to learn the different uses of common FRC sensors)
Last edited by smitikshah : 14-07-2016 at 13:57. Reason: im a n00b and prolly gave you the wrong idea
Unread 14-07-2016, 13:52
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
We use/have used:
- encoders
- gyro
- break beam sensors
- limit switches
- Vision camera
- distance sensors
Unread 14-07-2016, 14:31
FRC #4283
we are mostly interested in what ASD20 stated. Well we want to use Encoders and Gyros for our Autonomous so we can drive in a strait line and have better control on how we can code our Autonomous. The Distance Sensors and Limit Switches are mostly was stopping something, for example this year we did have a distance sensor to stop our in-take motor that would collect the bolder so it wouldn't burn the motor out.
i hope that helped
Unread 14-07-2016, 14:38
ASD20's Avatar
AKA: Andrew
What type of distance sensor?
Unread 14-07-2016, 14:52
FRC #4283
I dont know the type off the top of my head right now but ill see in any of my team members know. i do know it came from FTC
Unread 14-07-2016, 15:13
ASD20's Avatar
AKA: Andrew
Ultrasonic/Sonar? LIDAR/Laser/IR?
Unread 14-07-2016, 15:43
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Teams use more sensors not just because sensors are awesome, but because there is useful info to gather. This info can be used to make a more effective and robust robot.
If I were caught on a desert island and could only bring a few types of sensors with me, here's a few things I'd consider:
#1 - Encoders. Accurate measurement of wheel velocity and distance traveled on a drivetrain is crucial for a consistent autonomous routine. Also for consistency in wheeled shooters... Anywhere you would like something to be going a certain speed or distance, encoders are a better solution than hardcoding a motor control value.
One option: http://www.andymark.com/product-p/am-2899.htm
#2 - Gyroscope. Generally, the more expensive the better. Gyro gives you rotational velocity of your robot. By integrating (accumulating) it over time, you can deduce the angle of your robot relative to the angle you started the match at. This is very useful for autonomous navigation.
http://www.analog.com/en/products/me...-evaluationkit
#3 - Lidar Lite. This nice little sensor measures distance with a laser. By pointing it out the front of a bot, you can figure out how far you are from a wall, tote, or anything else solid. Useful for autonomous, or for helping the drivers position the robot.
http://www.robotshop.com/en/lidar-li...FQgzaQodcHAIUQ
#4 - Pneumatic pressure analog sensor. Allows the drivers to see how much air they have in reserve. Not used all the time during competition, but helpful for diagnosing issues when you can't walk out to the robot to check on it.
http://www.andymark.com/product-p/am-3219.htm
Unread 14-07-2016, 16:12
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
i hope that helped
We used this SPI port gyro that was designed to plug directly into the roboRio. Worked great. It's based on the Analog Devices ADXRS450 digital gyroscope chip. You can buy that chip in different board configurations. I'm not sure where to buy this specific packaging.
http://firstchoicebyandymark.com/fc16-000
I've heard good reviews from the NAV-X gryo / accelerometer board although we've haven't used it yet. It's definitely available for purchase.
http://www.andymark.com/product-p/am-3060a.htm
We use a Grayhill 63R optical encoder for measuring drive train distance traveled by coupling the encoder to a live axle on a wheel or the main gearbox. This technique works good for autonomous if you limit acceleration to prevent wheel slip.
http://www.digikey.com/catalog/en/partgroup/63r/11554
Good luck with your research and testing.
David
Unread 14-07-2016, 16:19
ASD20's Avatar
AKA: Andrew
We use a navx and I think it works well, even though I'm pretty sure our programmers have broken like 3. But then again, programmers break everything.
Unread 14-07-2016, 18:44
RoboChair's Avatar
AKA: Devin Castellucci
1678 likes to use Banner laser photo eye sensors for detecting balls, other objects, and sometimes field elements.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 15-07-2016, 17:18
FRC #4283
Thank you everyone thing is really helpful for us.
Unread 16-07-2016, 00:29
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
We used the CTRE magnetic encoders on our shooter to measure velocity, andymark's string potentiometer to measure position on our arms, these grayhill encoders on our drivetrain to measure velocity for (theoretical) automatic shifting, and a navx on our drivetrain for straight driving. I'm sure there are one or two sensors I am forgetting, but all of these are in closed loop P, PD, or PID control schemes. If you have any questions about how any of this works, let me know.
Unread 16-07-2016, 01:29
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
I gotta give a shout out to the humble potentiometer. We picked up a handful last year, and they proved super usefull this year too. They wire directly to an analog in Port, and can essentially give you abaolute position of a mechanism. Getting some with more than 300deg of rotation help protect it in case of over rotation.
Here's two versions I recommend keeping around:
Continuous rotation: http://www.digikey.com/product-detai...-103-ND/274005
10turn: http://www.digikey.com/product-detai...03L-ND/2058386
Unread 16-07-2016, 01:45
Steven Smith Steven Smith is offline
Steven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond reputeSteven Smith has a reputation beyond repute
One other question for you guys/gals as you discuss your sensor needs:
Are there any broad areas of sensing technology, how to do sensor integration (mechanical, electrical, programming), etc that you feel your teams could use help with?
AKA, in addition to WHAT to use, do you feel there are adequate resources on HOW/WHY to use sensors, that could be addressed by linking existing content or creating new content specific to FRC?
2013 - 2016 - Mentor - Robochargers 3005
2014 - 2016 - Mentor - FLL 5817 / 7913
2013 - Day I Die - Robot Fanatic
