Go to Post Iteration is something everyone can do. - [more]
Unread 07-16-2016, 08:26 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: What sensors do your teams use
If you are spinning it fast enough (quite likely), you can put the light/dark pattern directly onto the disk, and use a reflective optical sensor. If you do this, use a relatively inexpensive sensor and be ready to replace it, because it'll be located right next to that spinning wheel, and FRC robots have been known to collide with one another or the field elements. On occasion.
Unread 07-16-2016, 08:47 AM
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
You can also use a $10 hall effect sensor to do the same thing with a magnet. We found this pretty effective this year.
