Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 16-07-2016, 12:31
tedlasai tedlasai is offline
FRC #2996
tedlasai is an unknown quantity at this point
Running Multiple Robots
My team is running multiple robots during demos and we are having connectivity issues. We are sure it is with interference as the connection is better when only one robot is being used. Does anyone have suggestions on how to make this better. I have been told that making the router 5 Ghz would make it better. Please suggest anything to make it faster. Ideally we should be able to run 3 robots together at a fast speed.
Unread 16-07-2016, 13:50
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Re: Running Multiple Robots
One solution always is to just connect over Ethernet. We always bring an Ethernet cable to demos at least as a back up as we frequently have issues even with one robot.
Unread 17-07-2016, 09:59
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Using a 5 GHz router and computer should help. The 5 GHz band has more channels available to limit interference. Make sure that all pieces of the Wifi network has 5 GHz. The robot radio is already 5 GHz capable. You can use a tool like Wifi Analyser for Android or Windows 10 or Acrylic Wifi Home to help track Wifi interference. Make sure that there are no networks on overlapping channels.
I have also had success reducing interference in heavy Wifi environments making the robot network a hidden network. This prevents people's phones from trying to connect to the network. This was using the old D-Link radios, I don't know if this is needed for the new radios.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 17-07-2016, 10:12
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Someone had this same situation not too long ago and there was a pretty big thread about it. Here's a link: https://www.chiefdelphi.com/forums/s...d.php?t=148951
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
