Go to Post Physics is not a religion. - Jack Jones [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 16-07-2016, 17:20
Aren Siekmeier's Avatar
on walkabout
Re: Math Quiz 9
Originally Posted by Hitchhiker 42 View Post
What is a Monte Carlo simulation?
https://en.wikipedia.org/wiki/Monte_Carlo_method
Randomly sample the set of all line segments, and find the mean length of only the segments in the sample (a finite number chosen to suit your computational resources, rather than the uncountably infinite number in the entire set). If the sampling matches the probability distribution/weighting of the set, then the law of large numbers says your mean will approach the true mean as sample size increases.
Unread 16-07-2016, 17:21
Re: Math Quiz 9
Aren beat me to it.
One-line AWK script:
BEGIN{for(i=1;i<100000;i++){sum+=sqrt((rand()-rand())^2+(rand()-rand())^2);}print sum/i;}
Unread 16-07-2016, 21:33
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Math Quiz 9
I ran the Monte Carlo thing in a python script and the answers, each run with 1,000,000 trials, were all around 0.333. I'm gonna keep thinking, though, how to get an exact answer.
Your script has an error.
Compare it to the one-line AWK script I posted.
EDIT: I found the error - the value comes out to 0.521
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 16-07-2016, 21:38
FiMFanatic FiMFanatic is offline
FiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud ofFiMFanatic has much to be proud of
Re: Math Quiz 9
I am thinking the answer is a number that is very small (close to 0), as you can draw a ton more 0.000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 01 lines than you can 1 inch (or larger on a diagonal) lines.
Unread 16-07-2016, 21:43
Roboter
Rookie Year: 2015
Re: Math Quiz 9
Yet if you look at the Monte Carlo simulation, it looks closer to 0.521"
Unread 16-07-2016, 21:47
Re: Math Quiz 9
Unread 16-07-2016, 22:00
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is online now
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Math Quiz 9
My simple Python Monte Carlo script gave me an average of 0.521408 (or 0.52141 rounded to 5 digits) in ~5e9 iterations (10 miles of hiking worth).
Code is below:
import numpy as np
iterations = 10000000
avg = 0
for i in range(100000):
    for i in range(iterations):
        pos = np.random.rand(4)
        length = np.sqrt((pos[0]-pos[1])**2+(pos[2]-pos[3])**2)
        avg = (avg*i + length)/(i+1)
    with open("test.txt", "a") as f:
        f.write(str(avg)+'\n')
import numpy as np
f = np.loadtxt('test.txt')
print(np.average(f))
print(len(f))
I split it into two scripts just so I could stop the computation whenever without altering the result.
Edit: Reps to whoever finds the bug in my code and explains what it does.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-07-2016, 22:16
Re: Math Quiz 9
That is the correct answer. Reps to you
Unread 16-07-2016, 22:20
Re: Math Quiz 9
Now, how would you get the correct answer accurate to, let's say, 8 decimal places?
Unread 16-07-2016, 22:32
Re: Math Quiz 9
Makes no logical sense unless the question is improperly worded or bounded. You can fit an infinite number of lines in the box, and fact is, more lines closer to 0 in length fit in the box than lines averaging 0.52xxxx
Unread 16-07-2016, 22:35
Custom User Title
AKA: Cal
Re: Math Quiz 9
I think the problem is more "Choose two random points inside by a 1" square and measure the distance between them. Repeat infinitely. What's the average of those measurements?"
Unread 16-07-2016, 22:40
Re: Math Quiz 9
I agree then - your answer would make sense if that were the question. However, it was:
What's the average length of all the line segments which can be drawn inside a 1 inch square?
Unread 16-07-2016, 22:43
Custom User Title
AKA: Cal
Re: Math Quiz 9
If the problem is interpreted as you describe (What is the average length of all the line segments that could be packed into a 1" square at once without overlapping?), there would be no meaningful answer, since infinite line segments of any length l < sqrt(2)" could be fit within the square, as line segments have no thickness thus can be packed infinitely densely.
Unread 16-07-2016, 22:48
Re: Math Quiz 9
Exactly - hence why people struggled to answer I think......
Unread 17-07-2016, 02:34
on walkabout
Re: Math Quiz 9
Precisely ln(1+sqrt(2))/3 + sqrt(2)/15 + 2/15
Or approximately 0.52140543316
Rounded to 8 digits: 0.52140543
Rounded to 5 digits: 0.52141
A fun exercise in every integration tool I've ever learned, plus a cool rationalization trick I wasn't familiar with.
The computation took a bit to hash through some arithmetic errors and one silly differential error (chain rule!). In practice you probably wouldn't bother to do this (or use a symbolic manipulation tool like Mathematica - this is how I checked my work), and sometimes there is no closed form for the integral. To get 8 digits simply run a larger Monte Carlo simulation (a couple lines of code instead of several pages of derivation). In the end we are always limited to some finite number of digits, so numerical methods win out.
