Originally Posted by Ed Law
I don't quite understand your point and your example. From listening to dozens of talks from admission officers, I gathered that colleges are interested in 6 main areas:
1) GPA
2) Standardized test scores
3) Essays and supplemental questions if any
4) Extra-curricular activities and Leadership
5) Work experience and Entrepreneurship
6) Recommendation letters
They are not in any particular order. Every college will put different things as higher priority. A student has more control over some of these than others but I would argue that there is nothing on that list that the student has no control at all. These are things that admission officers use to see whether the student will be a good fit for the college. What students want to do with their life has nothing to do with these 6 things. Are you suggesting that students should do whatever they want and not care about what colleges are looking for? And none of the 6 areas are things that could help in their future whatever they decided to pursue? To avoid further misunderstanding, I don't advocate that students join a club or activity just to look good on their resume to help them get into a certain field. If they have no interest in that field, then they should not be joining that activity. If you don't have passion in what you do, it will show on the application. Joining many activities do not make you look good. It actually makes you look bad. On the other hand, I do encourage younger students to try as many things as they have time for, then narrow down to the things that they enjoy the most.
I am not looking for an argument with you. I am not trying to convince you that I am right. You work with your students the way you want to.
Back to the OP, since your friend is looking into going to a community college, what I said to you before is not as important. It is really his choice. Sometimes in life, you have to do what makes yourself happy but there are people around you that you have to consider also. It is not always about you.
To those 6, I would add "Class Rank", as GPA (in a vacuum) can be very deceptive when comparing school to school.
Good post.
