Go to Post When I see stuff like that, sometimes I say, "That's BRILLIANT, why didn't I think of that?" But I never like the answer. - dtengineering [more]
Unread 14-07-2016, 16:12
GRSICP GRSICP is online now
Greta Rauch
FRC #5822 (WolfByte)
GRSICP is an unknown quantity at this point
Sending Image from Camera to GRIP
Hi Everyone!
Our team did not use vision tracking this year so we are spending some time this summer figuring it out. We have learned how to process an image in GRIP and how to read the Network Tables in eclipse. However, we do not understand how to send an image from a live camera feed to GRIP. We are using a Logitech c270 HD Webcam and code in Java. Any tips or advice would be appreciated!
Thanks!
Greta
Team 5822 WolfByte
Unread 17-07-2016, 12:35
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Re: Sending Image from Camera to GRIP
If you are running GRIP on the driver station laptop or roboRIO, you can add the camera by clicking on Add Webcam in the sources section of GRIP. This section is in the bottom left corner of the window.
If you are trying to run GRIP on a Raspberry Pi, you'll have to follow the steps in this guide.
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 19-07-2016, 14:58
Greta Rauch
We tried that but cannot add the USB camera feed from the rio. Is there another way to access it?
Unread 21-07-2016, 22:08
GoldenGollem's Avatar
GoldenGollem GoldenGollem is offline
Java Programmer
FRC #2509 (Hutchinson Tigerbots)
Rookie Year: 2015
GoldenGollem is an unknown quantity at this point
Have you been able to access the camera via the RoboRio Webdashboard.
Unread 22-07-2016, 12:10
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
A couple of things:
1) I don't believe GRIP can use the camera if you're also sending that information to the driver station. So if you have robot code opening up the camera, it'll hog it and grip will not be able to see it
2) So if your robot code would normally open webcamX, then your GRIP code should now open webcamX instead
3) My opinion is that running GRIP on the roboRIO is to slow for anything other than learning a little bit about vision processing. If you have the resources to get a Kangaroo PC (~$100) I would highly recommend that instead. Additionally, there are instructions for using a raspberry pi.
3a) some extra context: If I recall, robot code wants to use about 60% of the processor running fairly basic robot code. GRIP also wants about 60% of the processor if you have what I would consider a reasonable quality image for vision processing. In my experience, we couldn't reduce the delay to much less than 2-3 seconds running grip on the roboRIO, even with reducing the quality of the image substantially.
Good luck
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 24-07-2016, 21:05
Greta Rauch
Yes we have
Thank you so much for the advice! Would you recommend a Kangaroo PC or a raspberry pi?
Unread 24-07-2016, 22:19
ahartnet's Avatar
I haven't used the raspberry pi. The kangaroo worked great, but there are a couple of gotchas. Mainly that the kangaroo will use the other ethernet port from the 2016 radio. Meaning toy either need an extra router, or be ok only connecting wirelessly
