#31
Re: Math Quiz 9
Edit - Now that I've had a chance to spend more than a few minutes on it, I see that wasn't the trick at all. I just need to go back and re-learn integration by parts. Edit2: Gathering up my paper notes, this is what I had so far (haven't double-checked everything yet): Checking the CRC Handbook integrals table (2000 edition): Quote:
I know or quickly found all but the forms with ln(1+√(1+y2)) in an online table of integrals or the CRC table: http://2000clicks.com/mathhelp/Calcu...rals.aspx#CatL Quote:
#32
Re: Math Quiz 9
Really nice work Aren and Gus.
Here's how I did it. |
#33
Re: Math Quiz 9
Now that this has been satisfactorily solved, I'll post a youtube video of this problem that I literally saw the week before Ether posted. I didn't feel right in just posting it, or claiming it as my own solution.
The problem gets to the 4ʃʃ(1-x)(1-y)√(x^2+y^2)dxdy GeeTwo derived, but then it does a polar coordinate substitution to make the integration "easier" It's another approach which gives a closed form solution, demonstrating that there can be multiple ways to validly solve a problem. |
#34
Re: Math Quiz 9
It makes no logical sense to say that there are "more" or "less" of one uncountably infinite thing than another uncountably infinite thing. |
#35
Re: Math Quiz 9
Re: Math Quiz 9
The question is worded just fine. It asks for an average length of all lines, not the length of the line of most frequent length.
#37
Re: Math Quiz 9
For example, would you be able to answer the question: "What is the average of all numbers between 0 and 1?"
#38
Re: Math Quiz 9
Also, we got several proper solutions...
#39
Re: Math Quiz 9
Cool, I much prefer how you dropped to the double integral, I don't think about stats enough when doing these things.
The immediate trig sub works wonders on the rest of it.Thanks for the link! |
#40
Re: Math Quiz 9
Re: Math Quiz 9
The integers are countably infinite. The reals are uncountably infinite. Quote:
![]() If you mean "the set of all even integers has an asymptotic density of ˝", then yes, it's meaningful. Otherwise, not. Last edited by Ether : 17-07-2016 at 23:08. |
#42
Re: Math Quiz 9
These solutions are quite above my mathematics level, but nonetheless I can somewhat follow along, thanks for the cool thread.
#43
Re: Math Quiz 9
The original question has no proper solution as worded. However, I do applaud the high level of solutions that were provided - well done. |
#44
Re: Math Quiz 9
I'm not sure what's missing... What extra information is being used in solving this problem? |
#45
Re: Math Quiz 9
A far as I am aware, any argument that decides the statement "Half of the integers are even." as meaningless can also be used to decide the concept of "average length of a line segment located within the unit square" as meaningless -- or worse. Edit: Quote:
Here's a bit more precise statement: For every set of consecutive integers with a non-zero, even number of members, exactly half are even. Last edited by GeeTwo : 18-07-2016 at 06:38. Reason: fixed cardinality, added last sentence. |
