Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
Unread 19-07-2016, 21:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Chain vs. Belts?!?
Originally Posted by DrewMatic View Post
But back to the belts... What sizes would you recommend. I know 100% that the sizes may vary between years and robots.
We ran belt our second year (2013 Ultimate Ascent) for the lighter-duty portion of our climber, and for our frisbee feeder (or more precisely, frisbee arrestor), and in our fourth year (2015 Recycle Rush) for the drive system exactly according to the AM-14U2 plans. IIRC, all were stock 15 tpi belt.
Obviously an edit:
Originally Posted by troy_dietz View Post
I think you may have your games mixed up a bit.
Yes, RR is RR is RR. I also fixed this above...
