Go to Post I suppose you need to let the kiddies (including Copioli) win a few now and then. - Andy Baker [more]
  #46   Spotlight this post!
Unread 20-07-2016, 21:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: what was the best shooting mechanism for 2016?
Analyzing how many of each type of shooter there was is similar to counting how many presidential candidates have blue eyes. The quantities of each might represent what teams initially perceived would serve them the best, but that decision making process was full of other variables like packaging, previous experience, and fabrication difficulty.
If you want to determine which was superior, then you need to determine what metrics you believe are important to the shooter and measure them.
% shots made would be a decent start.
  #47   Spotlight this post!
Unread 21-07-2016, 09:32
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Here is data on this subject from our qual match scouting at IRI. The usual noise of scouting data applies.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
  #48   Spotlight this post!
Unread 21-07-2016, 09:33
Kevin Leonard Kevin Leonard is online now
Professional Stat Padder
Very true, but I think it's a good start, and it's an easy analysis to do.
(2015-Present)
  #49   Spotlight this post!
Unread 21-07-2016, 13:42
aJASONt_angles's Avatar
aJASONt_angles aJASONt_angles is offline
Picture Taker of Sorts
AKA: Jason
FRC #4272 (Mavericks Boiler Robotics)
aJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud ofaJASONt_angles has much to be proud of
Best Shooting mechanism of 2016: Robonauts Grappling Hook
'Nuff Said
Mentor - FRC Team 4272 MBR Mechanical Design + Drive Coach (2014 - ...)
FRC Alumni - FRC Team 192 GRT (2013)
Mechanical Design Intern - AndyMark Inc.
Media Team - Indiana FIRST
  #50   Spotlight this post!
Unread 21-07-2016, 13:52
mwmac's Avatar
mwmac mwmac is online now
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Originally Posted by Kevin Leonard View Post
2122 showed up at their first regional just making low goals. They then improved by adding a climber and then eventually their extremely accurate high goal shot. They did, however, shoot from almost the ground.....
The type of shooter you choose isn't about which is objectively "the best", but rather which one fits your priorities and resources the best.
Thanks for the kind words. Your last sentence noted above is worthy of emphasis.
Having previous experience with hooded shooters (2012) and linear punch shooters (2014) we considered both before settling on a catapult design. Given the packaging constraints imposed by our desire to hang, be low bar capable and retain low and high goal scoring, our small spring catapult emerged as the best solution for us. Additionally, our picker design permitted us to quickly move the ball from low goal scoring position to catapult and back again if required by defense robots.
In terms of accuracy, on Carson through Einstein high goal accuracy was 79%. With respect to our low release point and its vulnerability to blockers, we experienced 2 blocked high goal shots out of 80 taken in teleop throughout CMP's.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
  #51   Spotlight this post!
Unread 21-07-2016, 15:05
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Any reason why 1619 has their own group?
  #52   Spotlight this post!
Unread 21-07-2016, 15:26
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Because even after a member of 1619 posted a picture and explained their shooter, it is unique enough that it doesn't quite fit in any of the other groups. It could probably be grouped with the double flywheel shooters, but it's enough of an outlier to earn its own category.
  #53   Spotlight this post!
Unread 21-07-2016, 19:08
AdamHeard's Avatar
Lead Mentor
We had the same shooter design (more or less).
I'd classify it closer to a single wheeled rotary shooter than a double flywheel shooter.
It's using flywheel(s) on one side to roll ball against a stationary wall and has a good deal of travel on the ball. A double wheeled shooter reacts off both wheels at once and doesn't have as much travel time on the ball.
  #54   Spotlight this post!
Unread 21-07-2016, 19:20
Well that shows how unique it is (or how dirty my glasses are). I thought it was the blue wheels on the two vertical shafts that provided the power, not the horizontal rows of Colsons. I guess those are for intake then.
