Go to Post Many people read ChiefDelphi, not just members of FRC teams. - JaneYoung [more]
Unread 20-07-2016, 21:29
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Cert Badge Material
Now, I have zero experience in these things. But it seems to my untrained eye that there should be more space for multiple certifications on the same card. That way, one person won't have to carry around a dozen cards.
Unread 20-07-2016, 21:42
shui054 shui054 is offline
AKA: Sam Hui
FRC #1257 (Parallel Universe)
shui054 is an unknown quantity at this point
Ohh got it thank you!! Wow can't believe I didn't notice that earlier...
Unread 21-07-2016, 00:14
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
So much depends on your budget. I would recommend white "credit card stock", either directly printed or bearing "name badge" labels. I fully concur that specific certifications should be modular on a single badge. You should consider stick-on paper/plastic labels, jewels (color coded), and custom brass images with pin backs. Your answer will probably like somewhere along this spectrum. Another possibility is to hang certifications below the name tag proper, rather like military ribbons.
Unread 21-07-2016, 00:39
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I was thinking something like heavy cardstock would work, although they would have to reprint them fairly often. That would make it less cost if kids lose them, however, especially if you have to outsource printing on plastic.
Photo paper might last a bit longer, although I'm not sure on that.
Some companies do plastic card printing, online. Starting with that and using cardstock replacements in cases of losing them could be a good idea.
