Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 20-07-2016, 22:10
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Announcing the mobile QDriverStation
Wow! This will be killer for robot testing. Nice work!
Unread 20-07-2016, 22:11
tjf's Avatar
tjf tjf is offline
FIRST Year, Best Year
AKA: Tim Flynn
FRC #1257 (Parallel Universe)
Rookie Year: 2016
tjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to beholdtjf is a splendid one to behold
I had tried to use their branch of it and get it to compile with minimal results.
Thank you so much for this, it'll be awesome for test-driving!
Does it support USB joysticks?
1257 (2016) - Student
1257 (2017) - Business Mentor (up in your business!)
KD2KRT
Unread 20-07-2016, 22:25
spat's Avatar
spat spat is offline
QDriverStation Developer
AKA: Alex Spataru
FRC #3794 (WinT)
spat is on a distinguished road
For the moment, it does not support USB joysticks (it only uses the virtual joystick). I can do that with SDL for the next release.
You can live for yourself today, or help build tomorrow for everyone
Unread 20-07-2016, 22:30
tjf's Avatar
tjf tjf is offline
AKA: Tim Flynn
Rookie Year: 2016
That'd be awesome! Starring your repo to keep an eye on it!
Keep up the good work!
KD2KRT
Unread 20-07-2016, 23:46
teku14's Avatar
teku14 teku14 is offline
http:
FRC #2614 (MARS)
teku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the rough
Where can I get a copy of the iOS version for sideloading?
Unread 21-07-2016, 09:52
spat's Avatar
AKA: Alex Spataru
FRC #3794 (WinT)
You will need to install the Qt SDK from here. Be sure to select iOS when installing it.
After Qt is installed, download the source code from GitHub and open QDriverStation.pro with Qt Creator.
Finally, click on the Run button to compile and deploy the application to your iOS device.
You may find these links useful:
Let me know if you need help with anything!
