Go to Post Sometimes it is more appropriate for an individual to listen than it is for him to speak. - JVN [more]
Unread 21-07-2016, 08:16
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: 25lb Drivetrain
Originally Posted by GeeTwo View Post
Finally, This was not a design point, but someone brought it up: I don't see how this could work as a kit frame. Kits usually ship in a box roughly 36" x 8" x 8", but this belly pan unit would have to ship as something rather larger. Even more critically, there is no good way to make this so that a team can select "long/square/wide" using a band saw. (And OBTW, the kitbots since at least 2012 have a LOT more options than are listed in the manual, if you are willing to put in a bit of skull work.) If you skipped the belly pan, much more is possible, but that misses the key feature that makes this such a weight saver.
Man, if only boxes came in other sizes.
Unread 21-07-2016, 08:33
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Just because I'm curious and I've never worked with belly pans before, what advantages/disadvantages do they offer? I've heard that they add a whole lot of torsional stiffness to a chassis in a more weight-efficient way than a cross bar, but other than that I'm not sure.
Unread 21-07-2016, 08:34
Flywheel Police
Also gives you a place to mount electronics.
Unread 21-07-2016, 09:36
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
And in a game like 2016, they protect the bottom of your robot.
Unread 21-07-2016, 10:45
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
Think of the belly pan like a bunch of strings or cables attached and tied everywhere at the base. It provides additional stiffness when the frame moves away from the belly pan and creates tension, but is very weak when in compression. Since it is attached all the way around, some part will always be in tension, providing more stiffness in the frame.
It is just one way of many ways to add stiffness to the frame. A disadvantage is that it is time consuming to make if you plan out all your electronics and place the holes for tapping and bolting then down. Also, depending on the rest of the frame members may not be necessary. In a case like this, where the frame members are light, the belly pan can give the stiffness needed to perform like a heavier drive train.
Unread 21-07-2016, 12:37
Flywheel Police
Using something like this allows you to create a bellypan very quickly and allows for flexibility in regards to electronics layouts.
Unread 21-07-2016, 12:43
Chris is me's Avatar
AKA: Pinecone
In terms of easily laying out electronics, a perforated polycarbonate belly pan is an excellent choice. In terms of structural rigidity, a large thin sheet of polycarbonate is not ideal. Something like Baltic birch plywood would be a better choice for a combination of rigid, lightweight, and flexible for mounting electronics.
Unread 21-07-2016, 15:50
Thanks to everyone for the info! I don't think my team really has the resources to make a bellypan, but it's always good to learn.
Unread 21-07-2016, 16:14
Knufire Knufire is offline
5188 used baltic birch plywood last season. It really doesn't get much easier than that. Just cut a square the size of your frame and rivet to the bottom. We got a 4'x8' sheet from the local Menards.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 21-07-2016, 16:35
Oh, you don't use a lightening pattern if you go with a plywood option? Nevermind, we could do that. (Now that I think about it, that should have been obvious.)
Though, my team has very strong aluminum welding capabilities, so we will probably stick with what has worked for us so far. Also, our robots have weighed in at about 100 pounds the past two years, so we should probably work more on increasing our scoring capability than trying to fix problems we've never had.
Unread 21-07-2016, 16:45
ASD20's Avatar
AKA: Andrew
You could do a little, though it probably won't save you much weight at all.
Unread 21-07-2016, 18:03
Nope.
https://scontent-lga3-1.xx.fbcdn.net...b2&oe=5821B827
