Go to Post JVN, Captain Mechanical Engineer, Mr. "Software is evil", has supported the CMU camera. I'm speechless. What's next? Copioli designing in imperial? - Karthik [more]
Go Back   Chief Delphi > Other > Math and Science
  #61   Spotlight this post!
Unread 19-07-2016, 18:13
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Math Quiz 9
Originally Posted by Richard Wallace View Post
So the distribution of lengths is Rayleigh. Neat example.
Rayleigh distributions can't have upper bounds though, right? This distribution will clearly have an upper bound at sqrt(2).
  #62   Spotlight this post!
Unread 19-07-2016, 19:24
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Math Quiz 9
What would the distribution look like if the line segments were contained in a cube (3D) boundary? That one may be easier to visualize using a Monte Carlo simulation.
Similar, but not quite a Rayleigh Distribution.
Originally Posted by Rayleigh distribution
The Rayleigh distribution, named for William Strutt, Lord Rayleigh, is the distribution of the magnitude of a two-dimensional random vector whose coordinates are independent, identically distributed, mean 0 normal variables.
After going to signed x ̅ = x1-x2 and y ̅ = y1-y2 components, but before collapsing the four quadrants, this problem is to evaluate the mean of the magnitude of a two-dimensional random vector whose coordinates are independent, identcially distributed, mean 0 triangular variables. That is, x ̅ and y ̅ are defined by the triangle function, max(0,1-abs(x)), rather than the normal distribution which would mean one proportional to e-ax2 (aka the Gaussian "bell curve"). As Caleb notes, this distribution, like the normal distribution, has no upper bound (an infinitely long tail).
If the working space were a cube, the small end of the distribution would start out with zero slope and a parabolic ramp of 4πr2. It would peak at a somewhat higher length (WAG of 0.6), have a similar change of curvature at length 1, and have an upper bound at √3.
Spoiler for Did you notice?:
For those who noticed, yes, the 2πr in the square case is the length of a circle of radius r, and 4πr2 is the area of a sphere of radius r in the cubic case. In the near-zero-radius limit, the size of the locus of points r units away from any given point is the population density.
Last edited by GeeTwo : 20-07-2016 at 06:20. Reason: tweaks and spoiler wrapper - and no thirds
  #63   Spotlight this post!
Unread 19-07-2016, 21:31
Re: Math Quiz 9
  #64   Spotlight this post!
Unread 20-07-2016, 15:44
Re: Math Quiz 9
Wrapping up some loose ends...
Originally Posted by smitikshah View Post
by "inside" are they allowed to touch the edge of the square?
Does it matter?
Why or why not? Explain.
  #65   Spotlight this post!
Unread 20-07-2016, 16:41
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Math Quiz 9
If I could,
The reason I don't think it matters is that let's say you were to take one end point of any line very very very close to the edge. If you keep pushing it infinetly closer, it's essentially on the edge already (limits woo), so it doesn't matter.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
  #66   Spotlight this post!
Unread 21-07-2016, 00:34
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Math Quiz 9
Enough hours have passed:
Allowing the borders of the square does NOT matter. The likelihood of one of the endpoints falling in any given area within the permissible bounds is proportional to the area. The lines at the edge of the square have length but zero area, so even if they're allowed, the selected point will "never" be on the edge. A bit more formally, the chances of a point on an edge being chosen is infinitesimally small and (excepting something massively discontinuous like a delta function) does not affect the integration over the area.
  #67   Spotlight this post!
Unread 21-07-2016, 01:48
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Re: Math Quiz 9
Originally Posted by GeeTwo View Post
Edit - and thanks, Caleb! I was thinking about attacking the same problem with the unit circle next, and I just realized I can adapt this technique to randomly pick r and theta with a uniform spatial distribution.
You can generate uniformly distributed coordinates in a unit circle much more easily, actually (if you look at genPolyPt() in my code, I do exactly that). Just setting r to the square root of a random number will correct the unevenness of the distribution.
  #68   Spotlight this post!
Unread 21-07-2016, 09:18
Re: Math Quiz 9
What's the average length of all the line segments whose endpoints both lie on the unit square's perimeter?
  #69   Spotlight this post!
Unread 21-07-2016, 11:36
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Math Quiz 9
Modified above Monte Carlo code to solve this:
import numpy as np
iterations = 100000
avg = 0
for i in range(1000):
    print(i)
    for j in range(iterations):
        perimeter = 4*np.random.rand(2)
        if perimeter[0] < 1:
            y1 = 0
            x1 = perimeter[0]
        elif perimeter [0] < 2:
            y1 = perimeter[0] - 1
            x1 = 1
        elif perimeter[0] < 3:
            y1 = 1
            x1 = 3 - perimeter[0]
        else:
            y1 = 4 - perimeter[0]
            x1 = 0
        if perimeter[1] < 1:
            y2 = 0
            x2 = perimeter[1]
        elif perimeter[1] < 2:
            y2 = perimeter[1] - 1
            x2 = 1
        elif perimeter[1] < 3:
            y2 = 1
            x2 = 3 - perimeter[1]
        else:
            y2 = 4 - perimeter[1]
            x2 = 0
        length = np.sqrt((x1-x2)**2+(y1-y2)**2)
        avg = (avg*j + length)/(j+1)
    with open("9.1.txt", "a") as f:
        f.write(str(avg)+'\n')
2.1e7 iterations yields 0.73511, standard deviation 0.00095 (between blocks averaging 1e6 iterations). More iterations will give a more accurate answer.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
  #70   Spotlight this post!
Unread 21-07-2016, 18:51
smitikshah's Avatar
smitikshah smitikshah is offline
Drive Coach
AKA: Smiti
FRC #2869 (Regal Eagles)
Rookie Year: 2015
smitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond reputesmitikshah has a reputation beyond repute
Re: Math Quiz 9
Originally Posted by Hitchhiker 42 View Post
If I could,
Ah okay that makes sense. Thanks!
  #71   Spotlight this post!
Unread 21-07-2016, 18:52
smitikshah's Avatar
Drive Coach
AKA: Smiti
Rookie Year: 2015
Re: Math Quiz 9
Thank you!
  #72   Spotlight this post!
Unread 22-07-2016, 11:30
Re: Math Quiz 9
Close enough
Two billion samples yields a value about 0.003% less than that. Plotting the average vs the number of samples gives a rough view of when you've reached the point of diminishing returns.
Note that this problem can be easily solved using all three methods discussed in this thread:
Numerical Integration
Symbolic Integration
Standard deviation is not so meaningful when the distribution looks this this.
Name:	Monte Carlo simulation (Delphi).png
ID:	20927  Click image for larger version
Name:	numerical integration (Octave).png
ID:	20928  Click image for larger version
Name:	symbolic integration (Maxima).png
ID:	20929  Click image for larger version
Name:	average vs samples.png
ID:	20930  Click image for larger version
  #73   Spotlight this post!
Unread 22-07-2016, 14:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Math Quiz 9
Yes, apart from the different piecing together the different lengths, every term in the integrals for this problem appeared in Aren's solution.
This is a non-sequitur. Z.B. was referring to the standard deviation across groups of samples, not standard deviation across line lengths. However, the graph of the population also suggests that a nominal MonteCarlo solution might do well to treat these as three separate populations, as Ether has done with the integration cases.
  • The "same side" population ramps up from zero, follows a third order polynomial, and goes back to zero at 1.0.
  • The "adjacent side" population ramps up linearly from zero to one, has a kink (continuous value, discontinuous slope), and decays back to zero at the square root of two. As Ether has indicated implicitly, note that this side has to be weighted double the other two, because given the first point, the second point can be on only one "same" side, one "opposite" side, or two "adjacent" sides.
  • The "opposite side" set has no population with length less than unity, 13+% of its values between 1.00 and 1.01, and 39+% of its lengths between 1.0 and 1.1, and the population continues to decay down to the square root of two.
Edit: By decay, I mean that the population curve is concave up as it approaches zero, not necessarily an exponential decay.
  #74   Spotlight this post!
Unread 22-07-2016, 18:42
Re: Math Quiz 9
5000 samples of sample size 1,000,000.
Mean of the sample means = 0.735089
Standard Error of the Mean = 0.000361
Name:	Standard Error of the Mean.png
  #75   Spotlight this post!
Unread 25-07-2016, 12:03
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Re: Math Quiz 9
OK, another follow-on challenge (cleared with Ether):
What is the average length of all the line segments which can be drawn within the unit circle (1 unit in radius, 2 units in diameter)?
Reps for both the first numeric (good to 1 part per million) and first closed form solution.
Edit: Of course, you must show your work in either case!
