pic: Outreach Frame/Prototyping Robot
Re: pic: Outreach Frame/Prototyping Robot
Before I even see the CAD model, I want to ask: why did you decide to build a dedicated Outreach Demo bot? Surely any robots from past games, especially Stronghold, would be fine for most demos. What can this specialized outreach bot do that any regular robot cannot?
I'm guessing that one of the reasons is to make a prototyping bot to put things on top of. I'm having trouble imagining what would happen if the prototyping robot happens to not fit a specific design. Has this kind of thing been done before? Now, on to the actual CAD:
This suggestion of bumpers for a demo bot might sound silly, but it could be useful to have at least one side that can mount a bumper for prototyping purposes.
Bumpers are probably going to mounted similar to how we've built most of our bumpers either pins or bolts on c or angle mounted to the frame. If you go to the CAD there are bumpers, they were taken off for this render to let you see the inside more easily. With the bumpers on the only part above the bumpers is the 80/20. The access to the chain can be done from over or underneath. The motor controllers do not actually go over the chain and the spacing will be placed such that maintenance should be fairly easy. The battery mount is fairly close to done actually. The strap isn't shown in the cad and the rear angle hasn't been placed yet but the battery was placed like that to make it easy to change without having to remove any modules that may go on top of it. After this years robot we wanted a battery that could be changed by one person very quickly. We are using Versaframe for most of the extrusion in the frame. Resource wise we have everything we need to make a WCD frame (Mill, Lathe, Drill Press, Pneumatic Rivet Gun, Etc) The 80/20 was actually donated to us by a sponsor. Thank you for your comments. I hope this helps to clear things up a bit. |
If you want to make it for prototyping, you are going to want the mechanism mount point as close to the ground as possible for mechanisms that are low to the ground and height matters for, like intakes or a lot of shooters this year. You can easily make a robot taller, but not shorter.
This robot mainly started as a design for a T-Shirt Cannon, then we decided that it would be nice of we could change the top modules and use it for prototyping mechanisms. Part of the reason we didn't want to do a vertical electronics board was because we were looking a a T-Shirt Cannon module and a few others that would already take up most if not all of the space above the frame. As for potential intake mechanisms most of the time we build those prototypes separately due to the fact that they can require cutouts or other specialized parts or locations for a competition robot. Most of our prototype shooters have been hand loaded during initial testing, then we work during integration and in CAD to make sure that they work together. This is why we didn't really design this with intakes in mind. The purpose of this protobot was mainly to prototype shooters and things that weren't necessarily specialized to any particular robot. I feel that how it is laid out works well for how our team works in the early stages of build season. It may not work for others out there but it fits well into how we work during the prototyping stage already. I hope this helps to clear up why it was designed this way.
