Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 25-07-2016, 18:12
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Drill gearboxes?
Originally Posted by Richard Wallace View Post
The source was Bosch.
I know because I arranged the original donation, back in 1997 when those motors, gearboxes, and housings were initially provided to FIRST by my employer, Emerson Electric Co., who owned part of Skil-Bosch at the time. After Bosch took complete ownership, they also took over the donation to FIRST.
Bosch is a great sponsor that has supported FIRST for a long time.
Interestingly enough, I happened to see a BOSCH drill transmission on a robot with a +4000 number. Made me smile and ask where they got it. Then we had to replace the BOSCH motor with a BAG motor to make it legal. Turns out this was actually a pretty simple swap.
For the OP:
You may want to check out 12V electric screw drivers. If they are 12V, they have a higher chance of having an easy to swap in FRC motor.
I believe that BOSCH makes a nice unit that 550 motor fit into, but be careful pressing the pinion as I think they are powdered metal and easy to crack. Milwaukee has a nice unit we used on 33 for the stinger back in 2012.
Electric screw drivers are easy to use a 1/4" driver to 3/8" or 1/2" socket to adapt to more "usual" FRC sized shafts.
