Go to Post You can't learn anything without breaking some stuff. - DonRotolo [more]
Unread 07-25-2016, 10:59 PM
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Who makes their own wheels?
In an effort to collaborate with my teaching comrades, I think a wheel project would be good. It is a great way to connect with a physics teacher with Newtons Laws of motion and overcoming the moment of inertia.
If any one has done this please offer advice.
We can use our Velox CNC to mill them out of aluminum and finish on a Lathe. We can also 3d print using PLA, ABS, and Polycarbonate.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 07-26-2016, 12:56 AM
Forhire Forhire is offline
AKA: Randy Smith
FRC #4060 (S.W.A.G. 4060)
Rookie Year: 2015
Forhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond reputeForhire has a reputation beyond repute
Re: Who makes their own wheels?
We used 2.5" 3D printed idler wheels on our track system this year. They held up better than expected and were very light weight. Our test wheels didn't have bearings and the later ones used 4 skate bearings to help support the hub. Without the stacked bearings the wheels would waller out quickly. We also used some large 6" 3D printed idlers on the prototype. They used two flange bearings and held up fine.
We replaced the large printed idlers with turned aluminum. I'd recommend turning your blanks and then machining the features. I blanked the idlers at work and then had the students mill the bearing pockets. The lathe at the school is pretty tired. I uploaded the video of the process. The students had to mill the soft jaws before milling the wheel.
https://www.youtube.com/watch?v=8Y0hI6mcwCg
We also modified some COTS idlers, these videos may give your some idea of the secondary operations.
https://www.youtube.com/watch?v=WkNYmihLryo
https://www.youtube.com/watch?v=EDhaW5d9uDk
If we need to ever make a lot of wheels we'd likely mill out a pattern and cast the blanks several at a time from scrap. Material cost on large wheels can add up quickly as round bar is typically a few bucks a pound. I think the large idlers were about 7 lbs each in material. We made four.
A method that I'd like to try would be to mold some from castable plastic resin in a silicone mold. Any teams casting them in plastic?
Unread 07-26-2016, 11:26 AM
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
We made custom hubs for 10" Harbor Freight pneumatic wheels this year from stacked laser-cut plywood plates. Worked great and were much lighter than the original hubs. I can find a picture/ render if there's interest.
Also experimented with making CNC-routed wood wheels before the season.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-26-2016, 11:52 AM
AKA: Randy Smith
Rookie Year: 2015
The version 2 of the wheel is downright cool. What a great basic cnc project. I would think machining them from something like birch plywood would prove very sturdy.
If some draft was designed in (or profiled with a tapered end mill) the wooden wheel could then be used as a pattern for casting in resin or even aluminum.
Unread 07-26-2016, 02:55 PM
AKA: Clint Brawley
FRC #0364 (Fusion)
I agree the wood wheels are downright cool.
Clint Brawley
USAF 1992-2013
Unread 07-26-2016, 09:24 PM
RoboChair's Avatar
AKA: Devin Castellucci
In the years we have done West Coast drive with traction wheels we have used custom wheels. We have our sponsor machine them for us but we could make them ourselves if we so desired.
One thing you should look into is milling cutters where the shank is smaller than the cutting flutes, look up T-slot cutters. This might let you make it all in one go on your router if you are clever, it's how our sponsor machines them.
The most important feature you should look at how to machine is the cross slot for installing the tread on the wheel.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 07-26-2016, 09:33 PM
AKA: Clint Brawley
FRC #0364 (Fusion)
Great information RoboChair, I had not thought of T-Slots for this purpose.
Clint Brawley
USAF 1992-2013
Unread 07-27-2016, 12:14 AM
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
WW2056D
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 07-27-2016, 12:27 AM
AdamHeard's Avatar
Lead Mentor
We used to make custom wheels, but there are so many good options now I don't see why 99.9% of teams should. We likely won't ever again.
Originally Posted by Gregor View Post
I was just thinking that's such a great quote.... Then clicked on the link and laughed.
Unread 07-27-2016, 12:28 AM
AKA: Clint Brawley
FRC #0364 (Fusion)
So 2056 doesn't teach students or collaborate with other teachers in the offseason? I agree that making custom wheels during the build season is not an ideal expenditure of time.
However, I thought my job was to educate students. Which I do year round. If my students know how to design and make a wheel, they will understand how to select the best wheel for our application.
I guess we could go the route of copying what the best teams do, but I prefer my students to understand why we do things.
Clint Brawley
USAF 1992-2013
Unread 07-27-2016, 12:37 AM
AdamHeard's Avatar
Lead Mentor
You can argue that the best of both worlds is to have your students design and make something that doesn't directly have more COTS options and is more analogous to the type of things they would design in season.
Also, it probabaly wasn't intentional but your tone seems to really dismiss system level design. Effective use of COTS parts is real engineering and exists in all industries. It's really an arbitrary line anyway, in terms of a robot scoring points is a wheel really all that different from a bolt? A connector? Etc...?
Unread 07-27-2016, 12:40 AM
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Unread 07-27-2016, 12:42 AM
Knufire Knufire is offline
Since there are so many good COTS options for drivetrain wheels, another suggestion might be looking into making custom wheels out of a softer rubber to use as intake or shooter wheels.
I know 125 cast their own urethane wheels for their 2012 shooter, there should be some pics up on CD of that process.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 07-27-2016, 12:46 AM
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
https://www.chiefdelphi.com/forums/s...4&postcount=14
https://www.chiefdelphi.com/forums/s...75&postcount=8
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
I like the idea of making shooter wheels. Currently on the COTS market there isn't much to be said for wheels with a large moment of inertia but remain grippy. Sure, there are the McMaster options, but those tend to be rather expensive.
Maybe something made of aluminum with holes to put steel rods into? This would also let you try balancing the wheel.
