Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 27-07-2016, 10:47
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: pic: Gears in Tube, Mecanum WCD
How are the wheels attached to the output shaft? Would a canter levered design like this be ideal with the lateral loads a mecanum drive experience?
Unread 27-07-2016, 10:49
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
The mecanums should be in the tube. Follow the everything-in-tube trend
Nice work!
Unread 27-07-2016, 10:55
Chris is me's Avatar
AKA: Pinecone
Lots of teams ran cantilevered designs like this in 2015 without problems.
The only thing to be careful of is, if you use a screw + washer to retain the wheel, make sure those stay tight, because more load is placed on them trying to unthread them.
Unread 27-07-2016, 10:59
FRC #5202
What would you use other than a screw/washer? I've only heard of WCDs that use them.
Unread 27-07-2016, 11:01
AKA: Pinecone
Snap rings are another popular choice, as they don't loosen, they are a little lighter, and it's easy to put a groove on a shaft on the lathe if you get the spacing right.
