Re: 6X 775 - 6X 1.625" Drive
Why use plate and standoff construction only to cantilever the wheels? Is the easier wheel change worth more difficult bumper mounting and greater stress in the structure?
I don't mean to poke at something that is meant to be slightly whimsical. But if there is a legitimate reasoning, I would just like to know what it is. |
.Nick most likely used plates instead of a piece of extrusion because it allowed him to maintain a decent amount of ground clearance. In order to do the same with a tube you'd end up tacking little plates on anyway, so you might as well simplify it. |
Such pockets!
Can we get a render of just the gearbox itself?
I'm also concerned with the gearbox mounting method. Would there be any issues with the fasteners bottoming out on each other before you can get a solid joint? |
This is very interesting but I don't think those little wheels would hold up long unless you added more of them. Ground clearance isn't the issue with this design at all, our 2013 robot was .250 off the ground and carpet was not an issue even when rolling over the pyramid corner plates.
This is awesome, hilarious, creative, well done, and a lot of other things. I just have to wonder... ![]() |
#7
Yes, I definitely asked myself if I should... multiple times. Then I remembered it's July and I had two days off work with nothing better to do, and Bailey and Rahul had already done a solid single speed 775 gearbox, so I figured why bother with something simple like that, might as well have some fun. |
#8
And talk about all the weight savings on those wheels!
#9
A 775pro drive gearbox could actually be viable. I know team 16 used 775pros for their drivetrain this year and it seemed to hold up really well with the unusual strain from the defenses. When talking to them at Worlds they said there weren't too many problems and it came down to the gearing. They would be better at describing it.
#10
You're only a few 10th's of an inch away from making a polyurethane roller into a wheel. Not that you'd do such a thing.
These tiny Colsons may actually see some wear over the course of 50 matches. |
#11
Nick: Is this setup actually lighter than a traditional WCD with 3" wheels? With the thicker plate and the gears and stuff, I would be inclined to say probably not. |
