Go to Post our family has no borders... - Greg Hainsworth [more]
Unread 28-07-2016, 13:38
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
8x 775pro, 2-speeds
If you're like most of us, the first thing you thought upon seeing Nick's 6 775pro drivetrain was, "But what do I do with the rest of my 775pros???"
Fear not.
If you're tired of having 775pros lying around everywhere and fed up with having available 40A circuits on your PDP, then this is the drivetrain for you!
2-Speed Version:
Specs:
8x 775pro
Adjusted theoretical speeds of 8.6 ft/s and 15.2 ft/s
22.8:1 and 12.9:1 reduction
1.5"x1.5" 1/16" wall 6061 square tubes for front and back crossmembers
1/8" diamond-cut aluminum bellypan with 1/4" wide strands
6x 3" x 0.875" wheels
#25 chain on 17t sprockets
9.9 lbs per module
23.3 lbs total
Single Speed Version:
Specs:
8x 775pro
Adjusted theoretical speed of 10.3 ft/s
19.0:1 reduction
6x 3" x 1.5" wheels
9.8 lbs per module
23.0 lbs total
Note that the weight differences from shifting are essentially canceled out by my use of wider wheels on the single speed version.
I think that the belt wrap on the 775 pulleys would be just fine (it's only a little worse than what 971 used all over the place this year),
but obviously I'd test it out before actually making something like this.
To fixture for welding, the inner plates and crossmembers are assembled using 610's roll pin and threaded rod method and the bellypan is riveted to the crossmembers.
After welding, the threaded rods can be removed if one so desires, but I'd imagine you wouldn't want to assemble with significant preload if you intend to remove them.
Apologies for the huge images.
Unread 28-07-2016, 13:42
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: 8x 775pro, 2-speeds
why are your wheels so big and not custom?
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 28-07-2016, 13:50
FRC Alumnus
FRC #1768
I tried, but our freshmen lost enthusiasm about filing the blocks of aluminum I gave them into Andymark Performance Wheels after only a few hours!
Unread 28-07-2016, 14:15
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Very nice... I love what you've done with the double first stage belts. The weight came out really nicely it looks like too. Given the price of waterjetting, this could be a great way to make the DT as fast as possible early in the season. Are you planning on releasing CAD for this?
Seconding the notion about the massive wheels. If it's not under 2", it's definitely too big.
Seriously though, what is it with you people and not using buttonheads?
EDIT: Given the space between plates, this could be a good candidate for 15mm wide belts.
Unread 28-07-2016, 14:17
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
With this drivetrain and some roughtop tread we can tear up twice as much field carpet. Thanks!
Unread 28-07-2016, 14:22
FRC Alumnus
FRC #1768
Thanks!
Unless I need them because of clearance issues, I prefer to avoid using button heads. The smaller hex size is much easier to strip and doesn't allow for as high tightening and loosening torque. Additionally, button heads are weaker (compare alloy steel button heads and socket head cap screws on McMaster Carr, minimum tensile strength of 120ksi for button heads, 170ksi for socket head cap screws).
Edit:
Sure, I'll upload both of them to GrabCAD.
Unread 28-07-2016, 14:24
Zac's Avatar
Zac Zac is offline
no team (Littleton Robotics - Mechanical Advantage)
Zac will become famous soon enough
In my experience button heads typically have a shallower hex, as well as a smaller hex size. With overzealous wench operators (common in these parts) this leads to stripped heads, stripped Allen wrenches, or both.
~Zac
Unread 28-07-2016, 14:27
RoboChair's Avatar
AKA: Devin Castellucci
~Zac
And sometimes even the fabled "handled" bolt
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 28-07-2016, 14:28
FRC Alumnus
FRC #1768
And sometimes even my 3/32" allen wrench being snapped in half by one of our members at champs...
Unread 28-07-2016, 14:44
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Yeah I generally only use button head or counter-sunk if I have to. However on the outisde of your drive I would have used button head since that's the very outside of the drive. It would make dealing with the bumper a bit easier.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 28-07-2016, 15:50
FRC Alumnus
FRC #1768
I lied. Here are Google Drive download links.
Two-Speed
Single-Speed
Yeah, if I were actually building this with the reality of bumper rules I'd probably just bite the bullet and countersink them all.
Unread 28-07-2016, 16:03
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
^+1
I'm a big fan of the following combo on a robot which is what we used:
1/4-20 countersunk
1/4-20 button head
10-32 socket head
We had a few T handle 5/32 allen keys so when combined with riv nuts most of the robot came apart with one tool. On our wheels we used 1/4-20 socket heads and 5/16-18 button heads for our axles and wheel hubs. This meant we could use a 3/16 allen T handle for both as well.
Nice drive Greg!
1058 PVC Pirates 2016 - xxxx
Unread 28-07-2016, 18:58
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
IF you are tired and sick of having 775-pros lying around everywhere, than we will buy some from you!
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
