Go to Post Everyone builds their robots uniquely, runs their teams differently, and prefers all kinds of flavors of ice cream. Now, we are seeing that folks vent and react differently to a frustrating situation. ... and that's ok. - Andy Baker [more]
Unread 25-07-2016, 07:35
azaclauson azaclauson is offline
FRC #5593
azaclauson is an unknown quantity at this point
Problem running C samples for roboRio
I'm new to the roboRio and to feel my way around things I'm attempting to run the C samples found here http://www.ni.com/download/labview-r...-2015/5558/en/.
I can successfully build, deploy and execute a sample to the roboRio but the app fails when it attempts to initialise the FPGA. The exact error text is shown below.
roboRio Hello
ERROR: -61200
Could not Open FPGA!
The error occurs in the NiFpga_Open function when the application attempts to load NiFpga_RoboRioFpga10.lvbitx. The -61200 error code has a handy comment:
* The operation could not be performed because the FPGA is busy operating in
* FPGA Interface C API mode. Stop all activities on the FPGA before requesting
* this operation.
static const NiFpga_Status NiFpga_Status_FpgaBusyFpgaInterfaceCApi = -61200;
Unfortunately I don't know what steps to stop all activities on the FPGA. I've tried removing a few likely looking scripts from init.d but to no avail.
Should the C samples be able to work with the FRC roboRio firmware? And if so how do I get the FPGA into the correct state to run them?
Unread 25-07-2016, 08:33
FRC #5593
Re: Problem running C samples for roboRio
I was able to solve my own problem by renaming the .lvbitx file in /usr/local.frc/bitfiles. I guess that stops the default image being loaded into the FPGA which means the C samples can then run.
Is there a way to unload the FPGA image from a roboRio bash terminal?
Unread 25-07-2016, 09:04
euhlmann's Avatar
euhlmann euhlmann is online now
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Does this option from the web dashboard work?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 25-07-2016, 18:40
FRC #5593
No it doesn't, that was one of the first things I tried as well .
Unread 26-07-2016, 08:44
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
That's disappointing. Have you reported the issue to FIRST? (If "Disable FPGA startup app" doesn't actually disable it, that would be a bug I think )
Unread 27-07-2016, 07:16
FRC #5593
Where should I report it? Here http://forums.usfirst.org/?
Unread 28-07-2016, 14:44
fsilberberg fsilberberg is online now
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Please submit bugs here: https://usfirst.collab.net/sf/tracke...cker.4_defects
Unread 29-07-2016, 06:27
FRC #5593
When attempting to create a new account on the TeamForge project I get the message below:
Permission Denied
x You have created the maximum number of users permitted for your TeamForge instance.
To purchase additional user accounts, please visit: http://www.collab.net/products/ctf/getlicensekey.html
Unread 29-07-2016, 21:11
WPILib Developer
FRC #0190
We're looking into it. I'll post again when we've resolved the issue (issue referring to the sign up limit).
Unread 04-08-2016, 12:53
WPILib Developer
FRC #0190
The Collabnet user issue has been fixed. However, something important to note: with the FRC image, this behavior is likely not a bug. The FRC Network Communications stack depends on the FPGA image, as the FPGA is disabled without an enable signal coming from a Driver Station. If teams were able to disable the image and load their own, they could bypass this behavior.
Unread 04-08-2016, 14:29
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Then why is there a "disable fpga startup app" option in the first place?
Unread 06-08-2016, 08:41
The roboRIO and other NI RIO products are used for more than FRC, and that includes loading your own FPGA bit file like the original poster is attempting to accomplish. The setting in question on the web page is useful for folks who have built a startup FPGA bitfile and no longer want it to be loaded at startup. It is confusing because there is no feedback as to how the FPGA is being loaded, so this option sounds good, and works in the right situation, but it isn't the option you are looking for.
For FRC, the bit file is loaded by the comms process, so the for nonFRC experimentation, I'd probably turn off the FRCNetComm daemon, reboot, and you'll be able to load your own FPGA for offseason, non robot, safe experiments. You can turn it back on or reimage to get things ready for FRC use.
Greg McKaskle
Unread 18-08-2016, 06:08
FRC #5593
I still get the same error message when trying to create a new Collabnet account at https://usfirst.collab.net/sf/sfmain/do/createUser/.
Disabling the /etc/rc5.d/S88FRCNetComm did stop the FRC FPGA bit file loading and allowed the NI roboRio C samples to run.
