Go to Post Both might accomplish the same "function" or "results" (perhaps a lift of some kind), but there are clear differences in simplicity, in cost, in maintainability, extensibility, and several other "ilities" -- which are a staple of engineering evaluation criteria. - msd [more]
Unread 27-07-2016, 17:59
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
pic: 1058 Low Expectations Intake Render
Unread 27-07-2016, 18:03
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: 1058 Low Expectations Intake Render
We built a very similar intake this past year but powered the rollers off of the upper feed system (to reduce motors and save weight), and direct-drove the angle-adjustment motor by internally coupling it to an extension inside the roller.
In retrospect it was way over-complicated and this looks like it would have been a much simpler (and easier to maintain) way to go.
Unread 28-07-2016, 16:38
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Where can I buy the pulleys that are next to the intake wheels and the belt/tubing thing that rounds the pulleys?
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 28-07-2016, 16:49
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
That tubing is called polycord (or Urethane Belting if you actually want to find it). McMaster. I am guessing that they 3d printed their pulleys.
Unread 28-07-2016, 17:14
AKA: Brendan Browne
We made the pulleys ourselves using 2.25" acetal that we got pretty cheap from a company in our town. We have access to three lathes and eager students so it wasn't too time consuming. We cut them to length, turned down a groove in the center to fit the cord, bored them to 1/2", and then hex broached them.
Looking back I probably would have just done what 188 Blizzard did which was use the Colson wheels as their pulleys. https://www.youtube.com/watch?v=UOMRgVIzI0M
That's the stuff. We used the 1/4" round solid core tubing.
1058 PVC Pirates 2016 - xxxx
