Go to Post Life is unfair. Learn to deal with it or be unhappy. - Joe Johnson [more]
Unread 28-07-2016, 21:21
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
8X 775 SS WCD
Okay, last one for a while I promise. This one is actually useful, unlike the 1.625" wheel one. This is a good setup to test some different things with a 775 drive, as it allows us to test anywhere from 4-8x 775s and see how the drive performs.
22.34lbs, with everything in picture. Only missing rivets.
12:60 32DP gear reduction off the motors.
16:70 20DP gear reduction to the wheel.
Theoretical free speed of 14.94fps; adjusted of 12.1fps.
The second gear reduction can also be switched to either of the following:
20:66; theoretical free 19.81fps; adjusted 16.05fps
14:72; theoretical free 12.71fps; adjusted 10.3fps
4"x1.5" VEX Colson wheels, 18T #25 sprockets with 12.768" spacing between wheels.
Tubing for testing will probably not actually be lightened, and a custom belly pan will probably not be manufactured (plywood or polycarb instead).
Custom parts include the gearbox plate for each side, 5 shafts cut to length per side (middle wheel shaft turned down on end to couple encoder), and side drive tubes. In this version I turned down the standoffs mounting the gearbox to be able to clamp around drive tube, but could just be a normal standoff to mount if desired.
Imgur Album
Questions/comments welcome. Let me know if you're interested in the CAD model, or would just like the print for the single gearbox plate.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 28-07-2016, 21:52
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: 8X 775 SS WCD
That is a pretty interesting setup! I love the low profile motor arrangement.
Did you calculate the torque at the wheels for eight 775 pros, that should be impressive?
Let us know how it goes.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 28-07-2016, 22:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: 8X 775 SS WCD
Hm I like your gearing arrangement. Why 1.5" wide wheels over the 7/8" wide?
Overall, it looks like your main saving is in space inside the chassis, would have been very useful this year. What is your opinion on 775pro drives in general?
Unread 28-07-2016, 22:42
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: 8X 775 SS WCD
I've noticed that you lighten all the rectangular tubing on your drivetrains. Is that something you would do in a typical FRC game? How about for something like Stronghold?
Unread 29-07-2016, 08:00
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: 8X 775 SS WCD
As a repeated user of 6cim drive, I am very curious of the results that are possible from the proposed testing. I am most interested in the results from the 6 775pro 14:72; theoretical free 12.71fps; adjusted 10.3fps setup.
Please keep us updated if you do happen to do this in the "offseason". Thanks.
