Go to Post Our wheels just keep falling off. - SenorZ [more]
Unread 29-07-2016, 07:38
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Compact 3CIM Single Speed Gearbox Review
Originally Posted by asid61 View Post
EDIT: 16ft/s free speed isn't too fast IMO, especially if you run 6 CIMs. On a 4 CIM drive your acceleration suffers, but 6 CIMs will make the difference.
The most effective 6-cim single speed drivetrain I've ever seen was geared to 10fps adjusted. 16fps is in the upper end of high gear for most 2-speed drivetrains I've seen (unless you're from CA, where time must move slower or something).
You might get away with 16fps in a game without much defense, but as soon as you try to drive through another robot you'll regret it, I think. A simple way to test this is to design your gearbox with a "VEX reduction", or an 84-tooth ratio. That way you can swap between ratios to find what you like best.
