Go to Post CNC machine, Something every FIRST kid wants in their bedroom :) - David Kelly [more]
Unread 29-07-2016, 18:09
crashingacastle's Avatar
crashingacastle crashingacastle is offline
AKA: Blake Johnson
FRC #0829 (Digital Goats)
Rookie Year: 2015
crashingacastle is an unknown quantity at this point
Controlling Talon SR using RobotC?
As a side project my team is deciding to create a t-shirt cannon to use at our school's home football games! We have already started construction and the program has been "finished".
The question that I have is regarding the Talon SR motor controller being used with ROBOTC and a VEX Cortex. How do I do it?
Right now I simply have it added as a 3-wire motor and set the speed as I normally would. Should I instead have it set as a digital output and set the SensorValue?
Any help would be appreciated.
Unread 29-07-2016, 22:39
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: Controlling Talon SR using RobotC?
That is exactly how it should be set. You could theoretically set it as a 269/393/393 turbo if you wanted to as well, since the 29 motor controller works the same as any other motor controller.
